Fiesta-Si.com • View topic - audio - Si speakers
It is currently Fri Mar 06, 2026 5:28 pm
 Post subject: audio - Si speakers
PostPosted: Fri Nov 10, 2006 12:36 pm
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Fri Nov 10, 2006 1:43 pm
The front speakers are 13cm and the rear are 10cm I believe.
The best setup with some decent sound on a budget would be 13cm coaxs up front and 6x9s in the back all on a 4 way amp, then set a high pass filter (around 80-125hhz) on the front speakers (should be able to set this up on the head unit or amp).
You can upgrade to components int he fornt but generally cost more and can make sound staging worse.
I would recommend (clicky)
You will need a headunit with at least to sets of preouts for this.
But overall I would say the above setup will give you good results for not much money. I was running those 7x10s with no subs for a while and everybody thought I had subs running.
As for wanting all infinity, if you was entering competitions and wanting huge specs go for it, but for a smaller budget system there are other brands (like listed above) which are good quslity and great value. :)
PostPosted: Fri Nov 10, 2006 2:32 pm
PostPosted: Fri Nov 10, 2006 4:13 pm
to put things in.
yeah my current headunit is wanky poo, so we will ignore it for now as i had planned on getting a decent headunit
will 4x50W do the job? or should i go more more more?
scotty - where would i get the pods from (to fit in the doors)?
both interesting routes i'll have a ponder
cheers chappies!
RR - TBC
PostPosted: Fri Nov 10, 2006 6:26 pm
It can be 4x0.5 for all it matters as you'll be amping them anyways, it doesn't make bob difference. Ignore that 4xblah trash anyways. Don't look at how good the amp is at creating heat (as thats all the wattage truely means) Look for functions. You want good high/low pass filters on each output. Good EQ with assignable frequencies and Q. Anything <£200 won't be amazing.
You'll need a single pre-out for my way and two pre-outs for Percy's way, depending on how you might set it up. You could get away with one. It depends on the functionality of your headunit.
http://www.audioscape.co.uk/index.php?id=16
Either buy the pukka audioscape ones or make your own for about 1/4 of the cost.
Talk Audio EDUs on building your own door pods.
http://www.talkaudio.co.uk/vbb/showthread.php?t=73733
http://www.talkaudio.co.uk/vbb/showthread.php?t=116661
I have a 106 with a sub in the boot :lol: I can fit about 5-6 tescos bags in the boot. One medium suitcase or a small midget - if you were so cruel. When I run out of space, i utilize the back seat! I highly doubt you'll get it sounding good - on a budget - without a sub.
PostPosted: Fri Nov 10, 2006 7:03 pm
PostPosted: Fri Nov 10, 2006 7:09 pm
PostPosted: Sat Nov 11, 2006 3:03 am
good set of component speakers in he front, with a good quality sub in the boot. no 6x9's
lovely
PostPosted: Sat Nov 11, 2006 2:37 pm
PostPosted: Sat Nov 11, 2006 5:21 pm
PostPosted: Sat Nov 11, 2006 5:37 pm
PostPosted: Sat Nov 11, 2006 9:21 pm
PostPosted: Sat Nov 11, 2006 10:15 pm
French Crew
French Crew
next six fields talk to me about the door pods, i made the ones in my clio and can give you a good run through on how to make them.
if i was workin on a budget id go for same comps as scott prob, with this sub...
and this amp to run it all
and dont forget
improtant to use good wiring, as it makes a massive difference
my system btw
oooh infact i may have some stuff in the loft you could have on the cheap
Untouchable
PostPosted: Sat Nov 11, 2006 10:29 pm
French Crew
French Crew
weeeeeell after looking in the loft i have
and these
used the amp to run my old sub, and then to run these speakers when i got my new amp.
did a very good job and sounded great. together they cost about £200 new.
if you fancy im sure we can do a deal
Untouchable
PostPosted: Sun Nov 12, 2006 10:35 pm
the rear speakers are 13's if you buy the speaker adaptors from autoleads!!!!!! scotty 8-)
PostPosted: Mon Nov 13, 2006 1:16 am
graham - we will definately be talking at sixfields then, might have to wait a while though till i can afford whatever i may want etc as i have to make plans
RR - TBC
