Fiesta-Si.com • View topic - making a 130ps motor!
It is currently Sat Mar 07, 2026 12:05 pm
 Post subject: making a 130ps motor!
PostPosted: Mon Aug 21, 2006 9:19 pm
i have hust put in a 105ps 1.8 motor in my si as my 1.6 went boom i got the 1.8 as i could not get a 2.0ltr in time had to replace fast as i needed car but iam i right saying i get make my engine a 130ps same as the rs1800 by putting the following on
130ps (ho) inlet manifold
2.0 maf sensor
2.0 throttle bodie
130ps cams
PostPosted: Tue Aug 22, 2006 12:59 am
You will need an ECU to run it all too now I don't think the RS1800 ECU will work due to PATS but I am sure it can be rewired and sorted.
Pretty sure using one of the 2.0 ECUs will do the job. So DEEP, DESK or DEWY should work.
PostPosted: Tue Aug 22, 2006 8:49 am
PostPosted: Tue Aug 22, 2006 6:48 pm
so wat do i need to do or which ecu do i need iam running my 105 ps on my 1.6 ecu, runs fine no probs i heard you use a 2.0 ltr ecu please lay it down cheers
PostPosted: Tue Aug 22, 2006 10:12 pm
You can use a mk3.5 RS1800 ecu as these run internal edis therefore will plug straight in. It wil also have be able to run the power steering type thing that stops the revs dropping if you know what i mean lol, because the mk3.5 RS's had PAS
