Fiesta-Si.com • View topic - Brakes & Suspension 2.0 ltr
It is currently Thu Mar 05, 2026 9:38 pm
PostPosted: Mon Jun 26, 2006 1:44 pm
he we are iam going to put the 2.0ltr in my si soon easy to do !
but the question is i have gmax suspension will these be burly enough for the 2.0 ltr i wont need to change them will i ??? as they are brand new.
also the brakes are poor on my si i will be wantin a rear disc conversion were can i get this and price??? what calipers etc also for the front what are people running ??
PostPosted: Mon Jun 26, 2006 1:57 pm
The suspension will be fine. Rear discs are a little pointless on it so just concentrate on the front brake set up. Most people stick 4WD Cossie brakes on their Fiesta and seem happy with it. Personally I'd go for something chunky up front like some Wilwoods. Other options are ST150, ST170 or RS2000 brakes. All go on with few alterations and make an improvement over the standard issue stuff.
PostPosted: Mon Jun 26, 2006 2:36 pm
suspension will be fine, thats what i have bought for my conversion. I have also picked myself up a pair of siera cosworth 4x4 calipers off ebay to help aid breaking. Tbh, there isnt much point in going to the cost of a rear brake conversion, as most of the breaking is done by the front. Have a look on http://www.fiesta-centre.co.uk/ they do the disk conversion kits for about £200 i think.
PostPosted: Mon Jun 26, 2006 5:57 pm
i'm planning on a 2.0 conversion nxt year, ive bought sum ebc discs and greenstuff pads made a good improvment i'm not going to change the brakes for the 2.0 conversion as i'm sure they will b fine for the job, although i may consider a change when say i get the cams done or somthing
am i right hear do si's have the same standard brakes as a rs turbo because when i bought my brakes, si's and rs1800 and turbos and that, all have the same disc and pads as the code number ???
PostPosted: Mon Jun 26, 2006 6:46 pm
Yeah they do. They're all the same. The back varies slightly. I think the backs are either 180 or 200mm depending on whether you have ABS or something.
PostPosted: Tue Jun 27, 2006 7:06 pm
so which brakes fit on the si ?? with which size rotors
