Fiesta-Si.com • View topic - breather filter !!
It is currently Thu Mar 05, 2026 9:38 pm
 Post subject: breather filter !!
PostPosted: Tue Jun 06, 2006 2:06 am
PostPosted: Tue Jun 06, 2006 11:55 am
There should be a breather hose going into the side of your airbox, you just stick the breather filter on the end of that when you remove the airbox (e.g. when you're fitting an induction kit)
You can buy them for a couple of quid from Halfrauds.
They help ventilate the crankcase, sometimes oil goes down the breather so some people fit a catchpot (usually a plastic bottle or similar) instead of a breather filter.
PostPosted: Tue Jun 06, 2006 11:09 pm
PostPosted: Wed Jun 07, 2006 10:56 am
You could probably get them from any motor spares place, or from Motorworld, Halfords or Ebay:
You can still use one on your breather hose even if you are still using the airbox with a K&N panel filter in it, just take the breather hose off the side of the airbox and fit the breather filter to the plastic clip at the end of it using a couple of jubilee clips to hold it there.
