Fiesta-Si.com • View topic - right, time for a brake upgrade!
It is currently Thu Mar 05, 2026 9:38 pm
PostPosted: Mon May 08, 2006 11:47 am
howdy! :) as my brakes on my fiesta r rubbish and have warped which is causing a lot of steering wheel juder under braking, i think its time for a change and upgrade them so that they will b able to cope with the 2.0 conversion nxt year.
i was thinking about a set of EBC discs and green stuff pads with a brake fluid change to DOT 5, what do u reacon would b a good upgrade?
PostPosted: Mon May 08, 2006 11:51 am
4x4 cosworth front brakes
i've just purchased a set to go on mine
might have them on before fitp
gotta read up on fitting them
PostPosted: Mon May 08, 2006 11:55 am
as said above!
Saph or Escort Cossie 4x4 Brakes!
Fit straight on with a small spacer!
there is a guide on Fiestaturbo.com how to fit them!
HTH
Tiller
PostPosted: Mon May 08, 2006 12:54 pm
I have a set of ST150 brakes off my 2.0 which I am breaking. Thery are the same size and power as the cossie setup but a lot newer. They don't need spacing but you do need to enlarge the holes on the hub to 12mm which is a very easy job. :)
PostPosted: Mon May 08, 2006 2:10 pm
Ap 4 pots :look:
PostPosted: Mon May 08, 2006 6:27 pm
Wilwood brakes are pretty decent for the price. I was less than impressed by Cossie brakes. :red:
PostPosted: Tue May 09, 2006 1:43 am
PostPosted: Tue May 09, 2006 10:30 am
PostPosted: Tue May 09, 2006 11:12 am
PostPosted: Tue May 09, 2006 11:14 am
