Fiesta-Si.com • View topic - Both beams at once?
It is currently Sat Mar 07, 2026 3:30 am
 Post subject: Both beams at once?
PostPosted: Mon Apr 24, 2006 6:54 pm
PostPosted: Mon Apr 24, 2006 7:22 pm
PostPosted: Mon Apr 24, 2006 11:22 pm
as i dont know much about where these wires are, where will i need to be looking mate? cheers
PostPosted: Mon May 29, 2006 3:19 pm
PostPosted: Mon May 29, 2006 3:42 pm
:lol: I wouldn't suggest it. Get some driving lamps on it or change your fogs for something more suited to continual use that project upwards.
Dip/Main runs on a twin filament bulb anyways so it'll just rinse the current.
PostPosted: Mon May 29, 2006 3:50 pm
havent bothered doing owt to it,
so brighter bulbs okay to use or is that stupid?
to be honest im just living with it :rolleyes:
i was gona put some driving lamps in the middle connected under the bonnet bit at the front but decided against it for the pissing about fitting them.
PostPosted: Mon May 29, 2006 5:19 pm
get a xennon convertion on it if u want brighter bulbs but it ull cost ya
PostPosted: Mon May 29, 2006 6:35 pm
I've heard that you can HID conversion kits, but they're big money, £700 upwards last i heard...
The xeon conversions is just using a normal H4 bulb with xeon gas in it, which burns brighter.. but at the same wattage, so thats better for the motor really...
I've been using the ring rally bulbs for 2 years now, and never had a problem with them so far *touches wood* but like i said, the inside chrome bit is starting to get a little burned.
Unfortuanatly only the MkIV Fiesta was catered for when producing aftermarket projecter headlights, which came with the angle eyes..
Would love them to start making them for the MkIII! :drool: :drool:
PostPosted: Mon May 29, 2006 8:20 pm
Or more simply, just pull the stalk back, as if your flashing someone, and keep it back. Then both your dipped and main beam will be on
PostPosted: Mon May 29, 2006 9:32 pm
PostPosted: Mon May 29, 2006 9:40 pm
PostPosted: Mon May 29, 2006 9:56 pm
