Fiesta-Si.com • View topic - Fuel rail for 2.0
It is currently Fri Mar 06, 2026 10:39 am
 Post subject: Fuel rail for 2.0
PostPosted: Fri Jan 14, 2011 9:35 pm
Those that have done the 2.0 conversion on a 1.6 Si - what fuel rail did you use?
My options seem to be:
a) Fit the 2.0 fuel rail as it is - preferred option, but it looks like the Mondeo flexible pipes are the wrong shape and will catch on the throttle linkage and be too short.
b) Swap the 2.0 injectors etc in to a 1.8/1.6 fuel rail so that I can use the correct Fiesta flexible pipes.
Apparently the 2.0 fuel rail has a slightly different pipe fitting that would stop me connecting it to the Fiesta pipes?
 Post subject: Re: Fuel rail for 2.0
PostPosted: Sat Jan 15, 2011 5:07 pm
i'm pretty sure i just used the mondeo fuel rail, but i cant fully remember :red: :lol:
PostPosted: Sat Jan 15, 2011 5:35 pm
I've got RS1800 rail with beige injectors from a 2.0
PostPosted: Sat Jan 15, 2011 7:30 pm
use the 2 litre one mate, that what ive done and shes running fine.
PostPosted: Sun Jan 16, 2011 1:12 am
Fiesta Si 2.0
Fiesta 1.1
Peugeot 206 sw 1.4
PostPosted: Wed Jan 19, 2011 10:58 pm
Thanks all. Thats two with the 2.0 fuel rail and two with the 1.8. Had a look in the members gallery and from the photos I have seen it looks like there's a mixture of people using each type (though still looks like the mondeo pipes will hit the throttle linkage to me). Guess I'll just see what looks like working best when I fit the engine. If anyone has photos of the mondeo pipes fitted to the car that could be useful.
PostPosted: Wed Jan 19, 2011 11:13 pm
There's mo difference mate there exactly the same as the 1.6 ones. All I've done is just move the pipe by the ISCV under the throtle bodie, that's all.
PostPosted: Thu Jan 20, 2011 12:44 am
That's the difference - mondeo pipe doesn't have the bend that is formed in to the 1.6/1.8 pipe to route it near the ISCV. Is this not going to chafe and stop the throttle closing properly?
Also doesn't reach this mounting bracket, though that's probably less of a problem
PostPosted: Mon Jan 24, 2011 12:33 am
Maybe you have the 2 litre fuel rail from a black top as I have recently done this and the 2 litre one bolted straight on and it had the formed bend in the pipe and still reached the mounting bracket!!!
I would just swap the pipes from your si rail and job done!!! :thumbsup:
TRACK READY 2.1 Si COMING SOON
The Mk2-
169bhp 1700cc Xflow 12.76 1/4mile
231bhp 2200cc Pinto 11.71 1/4mile
198bhp 2040cc Pinto TBC 1/4mile
PostPosted: Mon Jan 24, 2011 7:01 pm
I bought the 2.0 engine in the photo as a complete assembly with the fuel rail and plastic inlet manifold (just as it was taken out of a mondeo) so it's definitely from a silvertop. I might investigate swapping the pipes, but this site says the fittings are different:
