Fiesta-Si.com • View topic - Lacquer engine bay parts or not?
It is currently Fri Mar 06, 2026 10:39 am
PostPosted: Thu Jan 06, 2011 8:50 pm
Hey guys, got a question as per title. Im currently spraying LOADS of bits under the hood (as americans would put it), like everything that was silver on the zetec engine is getting re-painted silver for that new/fresh look, same goes for black bits too, its basically having a massive spring clean lol.
Now, do I lacquer these parts or not? I was watching chop shop on dave the other day and they had lacquered the bits they had painted - exhaust manifold being one bit, and it smoked up a treat.
Now, to be honest, im not fussed if its not lacquered because the paint itself isnt too bad, just a standard silver paint.
But whats your opinion on this? Things like rocker covers, water rails, exhaust manifold heat shield ect ect are getting painted.
PostPosted: Thu Jan 06, 2011 8:56 pm
if you do see if they do heat proof lacquer or somthing then it might not smoke or burn off but yeh if you did lacquer it then it would set it off alot better i rekon
TIME IS NEVER WASTED, WHEN YOUR WASTED ALL THE TIME
PostPosted: Thu Jan 06, 2011 9:01 pm
2 pack lacquer/clear is better! as it can resist the heat. heat proof lacquer is bullcrap and looks terrible when sprayed on!
you can buy a can of 2 pack lacquer on ebay from a company called nu-agane should be about £6-7 a can. and the results are like professional clear! but remember to wear a good dust mask when spraying as it smells nasty!!
PostPosted: Thu Jan 06, 2011 9:47 pm
Yes spray it shiny :)
PostPosted: Thu Jan 13, 2011 11:36 am
Would be better to powerdercoat IMO
But I'd like to see if using laquer works :)
PostPosted: Thu Jan 13, 2011 12:30 pm
A while ago I sprayed my cam cover a gorgeous silver, came out really well. Then I put laquer on it. It reacted with the paint straight away and turned the silver into a grey :( So be careful what paint you use it on, it might change the appearance :)
PostPosted: Thu Jan 13, 2011 10:16 pm
I didnt end up using any in the end. You can get engine lacquer but i opted out, just left the stuff with paint and no clear coat :)
