Fiesta-Si.com • View topic - Suspension UPgrade
It is currently Sat Mar 07, 2026 11:30 pm
 Post subject: Suspension UPgrade
PostPosted: Sun Oct 10, 2010 4:00 pm
Hi after ordering Poly Bushes for my car i notice that the top mounts would have lot of play around them as the old ones were oval and new ones were round i had a chat with a few people who are good friends of mine and thay told me it would be dangerous also the spring would have some play could camber problems an other problem .. here some pictures of problem you can see the gap a round which means the spring can move a bit
One of my mates i spoke to rebuild the top mount here some pictures
 Post subject: Re: Suspension UPgrade
PostPosted: Sat Oct 23, 2010 11:03 pm
Do the springs sit in the polybush correctly?
Are you using shortened shockers?
If your using shorter shockers, the springs force will hold the polybush in the top mounts anyway....
I these are the rear ones, it would not affect camber, as the suspension cannot affect that on the rear due to the rear beam
PostPosted: Sun Oct 24, 2010 12:06 am
Using spax suspension kit but may change the springs as i have BOGE Springs 35mm low as they are only 4 months old and done maybe 500 miles i have also painted the rear springs now took all the stuff off .
PostPosted: Sun Oct 24, 2010 12:11 am
They will be fine
