Fiesta-Si.com • View topic - About t2 and t3 turbos
It is currently Sat Mar 07, 2026 11:10 pm
 Post subject: About t2 and t3 turbos
PostPosted: Wed Sep 29, 2010 7:09 pm
I dont know much about turbos in general so just a few questions,
will a t3 turbo mount onto a t2 manifold and vis versa.. im pretty sure you cant but ive not come across them so i wouldnt no.
how much boost do they both run standard?
I WANTS BOOST!
PostPosted: Wed Sep 29, 2010 7:16 pm
The 2 turbos actually face different directions, not sure on boost, but you have to consider smaller turbos are quicker to spool.
PostPosted: Wed Sep 29, 2010 7:21 pm
the manifolds would be different from my understanding.
Each turbo would run whatever boost you want them to run, and they'll give different readings on the same PSI, it will probably more come down to what you're engine can take. the technical details of the turbo you're looking at will usually give a good indication of what it's maximum potential is. I'm sure someone can confirm this, I'm a turbo n00b too!
PostPosted: Wed Sep 29, 2010 9:06 pm
manifolds are different
PostPosted: Thu Sep 30, 2010 8:58 am
Escort RS Turbos on a t3 turbo only ran 7spi out the box IIRC or 11psi :lolz:
Fiesta was similar :)
