Fiesta-Si.com • View topic - Master cylinder
It is currently Sat Mar 07, 2026 11:09 pm
 Post subject: Master cylinder
PostPosted: Sun Aug 29, 2010 5:35 pm
Ive got a 1.4 carb fed cvh fiesta mk3, ive recently put mk1 mondeo v6 brakes on it and was wanting a bigger master cylinder and servo, whats the best items to use from another ford, alot of people are telling me to use a mondeo or escort set up, opinions?? I would rather it would just bolt straight in but will depends on the setup
 Post subject: Re: Master cylinder
PostPosted: Mon Aug 30, 2010 2:07 pm
The escort ones will bolt straight on apparently. I think some of the mondeo ones will fit but may need some modification, such as lever arm or something.
PostPosted: Mon Aug 30, 2010 8:45 pm
Nah escort ones require welding.
Mondeo mk2 one is bolt on, you just need to change the mounting holes and get 2 brake pipe ends converted from 8mm to 10mm
