Fiesta-Si.com • View topic - injectors
It is currently Sat Mar 07, 2026 1:25 pm
 Post subject: injectors
PostPosted: Mon Aug 23, 2010 7:31 pm
Does 115psi zetec-e have different size fuel injectors than the 130psi (xr3i/rs1800) or ar they all the same? How about the manifolds?
Thanks!
 Post subject: Re: injectors
PostPosted: Tue Aug 24, 2010 12:49 pm
115 zetec has smaller injectors, fit 2.0 ones
115 zetec if using the metal inlet manifold, it will be the "SO" one as used on the 1.6 zetec, you need a "HO" RS1800 one or fit a Focus 2.0ltr plastic one (will need to swap the idle control valve to a mondeo one tho)
Users browsing this forum: Bing [Bot] and 33 guests
