Fiesta-Si.com • View topic - Steering rack
It is currently Sat Mar 07, 2026 1:25 pm
 Post subject: Steering rack
PostPosted: Fri Aug 20, 2010 12:14 am
well lads, quick question, did any of the mk3s come with a shorter rack than standard models?? as in less turns of the wheel from lock to lock, would love a shorter one if there was one, thanks in advance :)
 Post subject: Re: Steering rack
PostPosted: Fri Aug 20, 2010 9:50 am
only the rs turbos had them
PostPosted: Fri Aug 20, 2010 1:11 pm
do you know what the lock from lock to lock is on them? and were they all without pas? thanks!! :thumbsup:
PostPosted: Tue Aug 24, 2010 12:49 pm
cant remember the lock to lock but non of the RST's had PAS
PostPosted: Mon Sep 20, 2010 1:04 am
anybody know what the turns lock to lock are on these? :| really thinking of getting one but wanna know before i buy, thanks in advance :halo:
PostPosted: Mon Sep 20, 2010 12:29 pm
rst 3.750
the rest 4.2
PostPosted: Mon Sep 20, 2010 10:47 pm
really??? so in a sense its a ford version of a quick rack.
anybody selling a rst steering rack in good nick? lol
PostPosted: Tue Sep 21, 2010 11:18 am
Would make sense as it was the flagship Fiesta.
Try fiesta turbo.com for a rack, although last time I looked, a decent one cost a fair bit.
PostPosted: Tue Sep 21, 2010 4:53 pm
Its that uncommon, I know my C2 VTS has a quicker steering rack than the other C2's.
As mentioned trying to get one in good nick might be a problem.
PostPosted: Tue Sep 21, 2010 10:44 pm
yeah thats what i was afraid of, plus im over the pond in ireland so have to factor in postage aswel, ill keep a look out tho :insanity:
PostPosted: Tue Nov 16, 2010 12:47 am
I think the Si with power steering is 2.8 turns. Not sure if you can use this rack without the rest of the power steering system?
PostPosted: Tue Nov 16, 2010 1:26 am
you should be able to, just remove the pipework and seal off the holes? :hmm:
PostPosted: Tue Nov 16, 2010 3:32 am
you could do i guess but wouldnt the steering be really heavy?
To rebuild?
PostPosted: Tue Nov 16, 2010 12:31 pm
if your going to do that then you need to put a conventiona;l rack and pinion rack init because thats got teeth on the rack and the power steering rack uses a spool valve and forces fluid from one end of the rack to the other and wont work if you just sealed off all the holes as it need fluid to work.
PostPosted: Tue Nov 16, 2010 1:15 pm
you will need to get a genuine ford rs rack, as i bought one for £17 new from a local motor factor and it had the same number of turns lock to lock as my 1.4 fiesta
PostPosted: Wed Nov 17, 2010 1:01 am
PostPosted: Wed Nov 17, 2010 10:53 am
yup, was a genuine ford rack too, but was reconditioned then sold by a local motor factor (kevin cooper), whenever my car fails the MOT on steering rack boots or play in the steering arms, i just replace the complete rack as its much cheaper that rack boots plus its quicker and easier tbh
Users browsing this forum: Bing [Bot] and 34 guests
