Fiesta-Si.com • View topic - RS1800 wheel
It is currently Sat Mar 07, 2026 10:59 am
 Post subject: RS1800 wheel
PostPosted: Wed Jul 07, 2010 9:06 pm
Just purchased an RS1800 steering wheel and was wondering how you change the steering wheel on a Si and put the RS1800 one on. Any help greatly appreciated
Ben
Check my project thread
 Post subject: Re: RS1800 wheel
PostPosted: Wed Jul 07, 2010 10:03 pm
i take it the rs one is pre air bag then you will need a pre air bag ignition barrel as the ignition barrel on a air bag model is longer
PostPosted: Wed Jul 07, 2010 11:55 pm
So this could be harder than i thought then?
PostPosted: Thu Jul 08, 2010 2:29 pm
shouldnt do, obv you need to get the wheel off first check the haynes manual for this, take the air bag off and its one big bolt :) size 22mm, also you will need to take the air bag bulb off your clock as its an mot failure if its on :) any more trouble let me know :)
PostPosted: Thu Jul 08, 2010 3:57 pm
So whats the deal with the ignition barrel?
Ben
PostPosted: Thu Jul 08, 2010 3:59 pm
never heard of that problem before ? so i couldnt tell you. also you have a pm
PostPosted: Thu Jul 08, 2010 4:25 pm
the metal housing of it it is longer on the air bag model to acomidate the clock spring so a non air bag steering wheel will rub
PostPosted: Thu Jul 08, 2010 4:36 pm
ah you can get a hub ? my old one had one, so have got a spare i can sell you if you want ben.
PostPosted: Thu Jul 08, 2010 6:10 pm
PostPosted: Fri Jul 09, 2010 11:03 am
yeah it can be an mot failure and when you take the air bag out make sure you disconnect the battery for more than 15 minutes or the air bag will go off. scarey when they go off accidently :)
PostPosted: Fri Jul 09, 2010 12:08 pm
PostPosted: Fri Jul 09, 2010 12:15 pm
its ok im going to help him and i have a hub of my Rs so its sorted.
PostPosted: Wed Jul 21, 2010 1:21 am
i found that my old Escort Xr3i steering wheel fitted fine with no rubbing issues
PostPosted: Sat Jul 31, 2010 9:54 pm
was your Si an air bag model and Escort one a pre air bag one though?
