Fiesta-Si.com • View topic - fiesta short shift (puma?)
It is currently Sat Mar 07, 2026 9:17 pm
PostPosted: Sun May 16, 2010 11:30 pm
not to sure but is it a puma? gear linkage? that you put in a fez and it acts as a short shift?
im not to sure what im going on about here but i read on here somewhere that if you put something off a puma onto a fez it acts as a short shift..
hopefully some1 can shed some light on this for me ha.
cheers.
I WANTS BOOST!
PostPosted: Sun May 16, 2010 11:33 pm
I've read that somewhere too :)
no idea if its right or not though :doh:
PostPosted: Mon May 17, 2010 9:09 am
Yes the Puma linkage acts as a shortshifter
I have one fitted in my 2.0 that i'm breaking. Two holes need to be drilled as it doesnt mount up to the holes already there and you need to knock up a mechanism to return it to neutral as the neutral return spring is in the Puma box where as it is in the Fiesta linkage
Scott
PostPosted: Mon May 17, 2010 4:40 pm
hmm i may be interested.. how did you make the neutral mechanism?
I WANTS BOOST!
PostPosted: Mon May 17, 2010 6:55 pm
Mine is pretty much already sold but the neutral on mine is just a spring under the centre console that makes the gear stick go back to neutral when it is out of gear
There is a guide by Excursion on his website, probably a link on ft.com, where he has welded a bar across the gear stick and then bolted that to the car to provide a stiffer way of bringing it back to neutral
Mine works fine though and its easy enough to get used to
Definately a worth while mod if you can find a puma linkage
Scott
PostPosted: Mon May 17, 2010 10:34 pm
ok thats cool, cheers for the info :)
I WANTS BOOST!
