Fiesta-Si.com • View topic - Amp wiring from battey help
It is currently Sat Mar 07, 2026 8:42 pm
PostPosted: Thu Apr 29, 2010 10:46 am
I need help on if there is a decent enough size hole from the engine bay into the back of the dashboard/front bit of car lol
I need to fit a 4gauge wire from the battery to the boot. there is already a 8 gauge in the car, but won't be good enough for the amp.
the 8 gauge disappears a very small hole, which isn't big enough.
Is there any bigger holes, with easier access to? without drilling through parts of the car? (that's my last option lol)
thanks in advance!
first post too.
cheers.
Dizzy.
Haha. Aint no lying either! :D
PostPosted: Thu Apr 29, 2010 12:49 pm
theres a grommet behind thew header tank i used onmy mk3.5 1.3
PostPosted: Thu Apr 29, 2010 12:58 pm
PostPosted: Thu Apr 29, 2010 1:03 pm
any random rust hole, theres normally plenty to choose from, lol
PostPosted: Thu Apr 29, 2010 4:05 pm
PostPosted: Thu Apr 29, 2010 4:22 pm
the wiring for the car goes through it :) plenty of room
in my days of being a badman, :lol: on that fiesta i had positive feed for 2 amps, dvd player, 7" screen and neons under the recaros and footwells and in glovebox, wired in the foglights, the normal wires on the battery.
one or two feeds :lol:
PostPosted: Thu Apr 29, 2010 4:39 pm
Alright!
If you say it's big enough then it is!
Mhm.
I had 2 JBL subs, 6 speakers, 2 amps, footwell neons, blue lights everywhere.
Just trying to get the subs into this one now. 1800watts. lool.
PostPosted: Thu Apr 29, 2010 11:28 pm
1800w :shock: you sure that will be loud enough? lol
To rebuild?
PostPosted: Fri Apr 30, 2010 12:11 am
your nearly as bad as my brother. He has gone through his 4th amp. He keeps blowing them up due to having overpowered subs :lolz:
I wired my amp/subs up into the 1.6 recently and if you fiddle to the far edge under the dash by the drivers side door you can run them up there and through into the engine bay.
Pain in the rear to get it through there though. Took my dad to shine a torch through the hole to be able to feed the cable through it.
PostPosted: Fri Apr 30, 2010 12:44 am
If you push it through on the gromit behind the header tank it will appear in the drivers foot well, from there is simple enough.
PostPosted: Fri Apr 30, 2010 9:08 pm
PostPosted: Fri Apr 30, 2010 9:12 pm
Care to quote some rms figures, I know some tinny PC speakers which are 1000w!
PostPosted: Sat May 01, 2010 9:16 am
PostPosted: Mon May 03, 2010 11:37 am
trust me its wide enough, i have a cable that could power the national grid running through mine :) tbh its all about the power your car can handle, whats point having loud speakers if you dont dynamat the car, will post a pic of my install ;)
PostPosted: Mon May 03, 2010 1:00 pm
