Fiesta-Si.com • View topic - Any1 have an ashley?
It is currently Sat Mar 07, 2026 3:57 pm
 Post subject: Any1 have an ashley?
PostPosted: Sun Apr 04, 2010 6:00 pm
Do ashley provide a body to central backbox mounting? the backbox on my ashley has a central mount that was used before but the car has the standard os mounting which i'm sure would not hold the backbox properly if used. It does have this mounting point also but it's far to heavy and would sit far to high if used.
Just wondered for when I go breakers if there is a certain bolt on mount that I can use to connect it to, or if I have to get one welded on :? really hoping its not a weld job.
Also if anybody knows the suitable u-clamp sizes that'd be great also, I measured the OD at 55mm but that doesn't seem right to me :?
Happy Easter :halo:
EDIT> just taken a look and with any luck i'll be able to use the existing car mount and hook it up to the standard back boxes mount, my fiesta exhaust already hangs to high and to far to the left so should align the ashley perfectly :D
