Fiesta-Si.com • View topic - Power outputs of a 2.0 Fsi
It is currently Sat Mar 07, 2026 12:04 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Feb 09, 2010 11:46 pm
What Bhp/Torque can i expect from my soon to be finished 2.0 si? running the 1600 inlet and exhaust still, with the 1.6 box?
i drove a 2.5 v6 mondeo earlyer that was mental obviously i dont expect it to be as quick as that,
how quick does the 2.0 with 1.6 box feel?
cheers :thumbsup:
I WANTS BOOST!
PostPosted: Wed Feb 10, 2010 12:06 am
mine had a RS1800 throttle body at the time though, would think the 1600 one would hold it back quite a bit though, as for 1600 gearbox, i like it accelerates really well in 3rd and 4th
PostPosted: Wed Feb 10, 2010 12:27 am
The 2.0s seem to make 120-140 depends on a whole range of things.
Mine pulled upto 65 in second gear which was fun.
PostPosted: Wed Feb 10, 2010 3:24 am
ok sweet cheers for that, so i should expect 110ish or less?
I WANTS BOOST!
PostPosted: Wed Feb 10, 2010 4:14 am
with that inlet and that exhaust manifold... im guessing still with the egr? around 115-120... my escort had a 1.6 inlet and 2.0 engine and that was a tad slower than a 115bhp 1.8 escort... but when i put a 4 branch mani and rs1800 inlet it would leave it.
with the egr removed and an rs1800 inlet you'll easily see standard 135 i recon.
Msn - ryan@areyouserios.com
PostPosted: Wed Feb 10, 2010 1:51 pm
PostPosted: Wed Feb 10, 2010 10:38 pm
which mondeo was you on about because if your talking about the st24 or st200 i cant imagine the 2.0 fiesta not being far behind, i hear it being like saxo vts speed which is 0-60 in 7.2 seconds (saxo 120bhp/2.0 zetec 136bhp) which i think is quicker than the mondy's. If your talking about the st220 then you will need more power :devil:
PostPosted: Fri Feb 12, 2010 3:20 pm
if you take off the egr, will it still pass mots? on the emissions
I WANTS BOOST!
PostPosted: Fri Feb 12, 2010 3:52 pm
Yes a 2.0 Fiesta and a Saxo VTS are pretty much perfectly even, we tried it when I had my Saxo and Matt had a 2.0.
Removing the egr won't cause any problems with emissions, its there to warm up the CAT faster. But an emissions test shouldn't be done when its cold anyway, basically it may take slightly longer for your emissions to come down but this is no problem at all.
PostPosted: Fri Feb 12, 2010 4:01 pm
My 2.0L Had 131bhp that was with a 1.6 inlet, standard exhaust system and a K&N. :)
Had 149.9Ft/lb of torque :chill:
I had 5 Gearboxes in the 6months i had the 2.0l in, 2xSi's, 2x 1.8 Escort, 1x Escort Derv Box :)
PostPosted: Fri Feb 12, 2010 4:14 pm
Shame I never got a Saxo RR'd, but they do make 125-130 with induction and exhaust.
If I remember at the top end of the scale my Saxo did start to pull away ever so slighly.
With that I do still miss my fiesta.
PostPosted: Fri Feb 12, 2010 6:34 pm
with the price of them you could start again as a project ;) you know you want to :halo:
PostPosted: Thu Feb 18, 2010 2:12 am
Sweet just got hold of a 1800 inlet, injector manifold, and exhaust manifold! woo
I WANTS BOOST!
PostPosted: Mon Mar 01, 2010 1:12 am
Got a 1800 inlet manifold and took a 1800 exhaust manifold with no egr off of a scrap escort the other day :D
I WANTS BOOST!
PostPosted: Mon Mar 01, 2010 1:35 pm
PostPosted: Mon Mar 01, 2010 6:59 pm
what box did you have in yours?
PostPosted: Mon Mar 01, 2010 7:34 pm
I had the 1.6si box too
PostPosted: Mon Mar 01, 2010 7:40 pm
would you say its worth getting a longer ratio box for the 2.0 conversion like the rsturbo box or keep the 1.6?
PostPosted: Mon Mar 01, 2010 7:51 pm
Pretty sure the ratios are the same on the RST, mine went up to 70 in 2nd so long enough.
