Fiesta-Si.com • View topic - Bigger master cylinder
It is currently Sat Mar 07, 2026 8:53 pm
 Post subject: Bigger master cylinder
PostPosted: Thu Jan 21, 2010 8:08 pm
thinking of doin a rear disc conversion on my si and i have 283mm mondy v6 brakes up front.
but i heared that the rear discs lock up bad if you use standard master cylinder, so is there a bigger better one u can fit?
PostPosted: Thu Jan 21, 2010 9:43 pm
Rear brakes only lock up of you have standard on the front, as your putting bigger on the front, it should be fine!
PostPosted: Thu Jan 21, 2010 11:25 pm
i think i could do with 1 anyway mate as pedal travels is quite bad.
PostPosted: Fri Jan 22, 2010 1:16 am
Sure you have enough fluid and that its doesnt need changing?
PostPosted: Fri Jan 22, 2010 7:57 pm
yea think so. its the bigger pistons i think mate.
my mates escort with 300mm mondeo v6 brakes and my other mates 106 rallye with GTI-6 brakes are both exactly the same.
but my mate with the 106 put the gti 6 master cylinder on his and he sed it was loads better!
PostPosted: Sun Jan 24, 2010 8:28 pm
PostPosted: Mon Jan 25, 2010 12:36 am
PostPosted: Mon Jan 25, 2010 12:37 am
bs is is bull sh it
fromt what ive read a secort master cylinder is a uprgrade but not to sure which one
PostPosted: Mon Jan 25, 2010 10:31 am
escort one from a mk6 without abs i think
PostPosted: Mon Jan 25, 2010 4:38 pm
as said. Bullsh*t.
It was a typical ft.com thing. One person, most likely a chav... put rear discs on and when he crashed claimed that it was the rear discs which had locked his rear end up and made him crash.
When really it was probably his driving or shonky car.
One of them things that people take as gospel cause somebody said about it once.
I know plenty of people that have had rear discs, with standard fronts and bigger fronts, also with the bigger escort mk6 servo. And nothing like that happened to them.
My pickup didnt even lock up the back end! and that was lighter on the back end so surely that would have done it easier?
PostPosted: Mon Jan 25, 2010 8:02 pm
ahh rite lol
so do you guys reckon ill need the bigger master then?
or shall i just try it 1st and see what its like?
i didnt realise you had discs on the back of the pickup.
my old car used to lock up the back brakes at low speeds. and that was the standard drums. lol was great 4 a bit of left foot braking into hairpins thou lol
PostPosted: Mon Jan 25, 2010 8:12 pm
Try it without. If the pedal is sh*t then change it. And then you will have a mental pedal :lol:
It had rear discs when it turned red.
PostPosted: Mon Jan 25, 2010 8:23 pm
ai ill have a play and see what happens!
does it make much difference to braking then??
thinking about it now thou my mate got 300MM Brakes on the front of his scort and rs2ks on the back and he doesnt get any problems.
PostPosted: Mon Jan 25, 2010 8:29 pm
It makes the pedal very easy to lock the car up. Or so I found! :lol:
Worth while if your pedal has got shite when upgrading to bigger brakes
PostPosted: Mon Jan 25, 2010 8:39 pm
aww rite nice.
u cant with which my front 1s now. they are awesome at high speeds but if your going fairly slow. you either gota stop slowly ish or you lock up lol
