Fiesta-Si.com • View topic - rear disc conversion
It is currently Mon Mar 09, 2026 4:36 am
 Post subject: rear disc conversion
PostPosted: Sun Jan 10, 2010 1:46 pm
Does anyone recommend the fiesta-centre's rear disc conversion? does it actually make a difference? :nerd:
 Post subject: Re: rear disc conversion
PostPosted: Wed Jan 13, 2010 9:40 am
as a kit its got everything you need to bolt it on..the one i bought for my then project i made my own brackets to run escos vented discs on the back...but that was going to be a track based car..so very overkill on a road car. the dimensions of the hubs mean you gain some extra width in rear track. i never got to actually use them. you may need to do the mk6 escort servo/master cyl mod.
personally id be on the hunt for some 130 spec escort gear. coupled with something decent up front and the master cyl mod...you probs wont be needing another upgrade any time soon :lol:
PostPosted: Wed Jan 13, 2010 11:22 am
Is a good kit, but upgrade your front brakes first or you will end up spinning when you hit the brakes.
PostPosted: Wed Jan 13, 2010 2:42 pm
I am guessing this is just for looks, as if you have yet to upgrade the front breaks you deffo will not be needing uprated rears.
PostPosted: Wed Jan 13, 2010 2:47 pm
With that a good set of ST150/cossie up front will be more than enough.
PostPosted: Thu Jan 14, 2010 10:26 pm
what exactly do i need to buy to ugrade the front to the cossie set up? im guessing cossie unless any of you guys recommend any different because i have 15" wheels which i dont fancy goin any bigger anytime soon, and iv read on here thats as big as i can go.
PostPosted: Thu Jan 14, 2010 10:55 pm
Fiesta ST150 brake conversion is the easiest. The disks and calipers bolt staight on. I think 15's are also the minimum though, as they are about 300mm.
Can be pretty costly though because scrappys know that people want them for their MK3/4/5/6's and some escorts i think.
PostPosted: Thu Jan 14, 2010 11:00 pm
im after keeping costs down as i really want a 2.0 soon. how much does the discs and calipers off st150 cost on average?
PostPosted: Thu Jan 14, 2010 11:10 pm
About £200-£300
PostPosted: Sat Jan 16, 2010 10:41 am
My calipers and disks went for around £55 i think. Add a couple of bolts/ washers and you could have the setup for £60 (the disks/ pads on mine were good condition).
PostPosted: Sat Jan 16, 2010 11:49 am
what was they off? would they of fit the escort gti wheels?
PostPosted: Sat Jan 16, 2010 7:10 pm
Sorry, they were sierra 4x4 cosworth front disks/ calipers. They fitted my 15" alloys, just. I think they will fit nearly all 15" alloys, however I have heard that some 15" alloys will need slight spacing to make fit.
PostPosted: Tue Jan 19, 2010 12:13 am
im after the cosworth ones, are they easy to fit?
PostPosted: Tue Jan 19, 2010 12:32 am
Cosworth 4x4 and ST150 are the same to fit, you just need to space the cossie ones where the ST ones are right. Not a problem really.
I fitted ST brakes to my fiesta so if you need any help give us a shout.
PostPosted: Tue Jan 19, 2010 9:12 am
Very simple fit, just need a couple of washers and the right sized bolts.
PostPosted: Tue Jan 19, 2010 7:02 pm
there are a few guides about front brakes upgrades.
http://www.fiestaturbo.com/forums/exten ... 4e23581306
viewtopic.php?f=16&t=10262&hilit=brakes
viewtopic.php?f=16&t=8512&hilit=brakes
viewtopic.php?f=16&t=15594&p=201368&hilit=brakes#p201368
PostPosted: Tue Jan 19, 2010 7:59 pm
good guides there cheers
and percy when the weather gets warmer and days get longer i will take you up on that offer, im thinkin to go down the st break setup now after checkin the guides out.
Users browsing this forum: Google [Bot] and 14 guests
