Fiesta-Si.com • View topic - are rs1800 cams the same as 2L cams?
It is currently Sat Mar 07, 2026 11:09 pm
PostPosted: Mon Oct 19, 2009 8:21 pm
are they diffrent in any way what so ever?>
PostPosted: Mon Oct 19, 2009 9:20 pm
they apear to be the same in lift profile 9.7mm inlet and 8.6mm exhaust but would look like they have different identification casting rings on them, there is some info on web site below and just to check been out in the garage to look at mine and it seems like might be correct and i have a RS1800 and a 2litre 136 pair
RS1800 inlet
2litre 136 inlet
PostPosted: Mon Oct 19, 2009 9:42 pm
soo can you use 2L cams in a 1.8?
PostPosted: Mon Oct 19, 2009 9:46 pm
yes, have you got 130 RS ones at the moment? use of the 2litre 136 cams is a common upgrade to replace 115 cams
PostPosted: Mon Oct 19, 2009 10:01 pm
my engine is the 115ps one just want to make sure as i have a rs1800 ecu on its way
PostPosted: Mon Oct 19, 2009 10:03 pm
exhaust cams are supposed to be the same but inlet cams are meant to be different.
think about it, 130bhp from a 1.8 or 137bhp from a 2.0, seems to me like the 1.8 has slightly wilder cams, thats why i have rs1800 cams in my 2.0l and it flies
PostPosted: Mon Oct 19, 2009 10:14 pm
so the rs1800 ones are more powerfull to a sence
PostPosted: Mon Oct 19, 2009 10:49 pm
well some say not but i who knows, the 2.0l ones are still an improvement whatever over std cams.
http://www.holdtilsold.co.uk/main/showthread.php?tid=71
PostPosted: Mon Oct 19, 2009 11:18 pm
FYI i have some 2.0 cams with pulleys, and will do them cheaper than in that add!
PostPosted: Tue Oct 20, 2009 8:01 pm
PostPosted: Tue Oct 20, 2009 8:20 pm
thanks ... does any one know where i can get some thing like kent pullies from in blue?
PostPosted: Tue Oct 20, 2009 9:40 pm
PostPosted: Tue Oct 20, 2009 10:02 pm
i have obx , they are bit heavier than kent ones but look miles better imo
PostPosted: Tue Oct 20, 2009 10:04 pm
nice how much?
PostPosted: Tue Oct 20, 2009 10:23 pm
