Fiesta-Si.com • View topic - 1.8 engine
It is currently Sat Mar 07, 2026 11:10 pm
 Post subject: 1.8 engine
PostPosted: Sat Oct 10, 2009 1:49 pm
right i am now allowed to get a 1.8 in my car question is will a 1.8 fit in with out changing all the sump like u have to do in the 2L build
and also what do i need to make it into the 130bhp engine?
 Post subject: Re: 1.8 engine
PostPosted: Sat Oct 10, 2009 6:52 pm
a 1.8 drops straight in with no mods
for 130bhp find a rs1800 engine or a xr3i 130 bhp lump
you can keep the wiring looms the same aslong as you have a internal edis ecu if not the its simply a case of swapping to a older loom and takes 20min todo
PostPosted: Sat Oct 10, 2009 8:25 pm
to mod a 115bhp 1800 engine to 130spec just requires change of cams and ECU
PostPosted: Sun Oct 11, 2009 4:52 pm
PostPosted: Mon Oct 12, 2009 7:11 pm
PostPosted: Mon Oct 12, 2009 10:23 pm
not mch 2 do then 2L head 1.8 "rs" injectors or do the 2L ones work? and ecu
PostPosted: Tue Oct 13, 2009 6:57 am
PostPosted: Tue Oct 13, 2009 7:47 am
is the 1.8 115ps maf the same as a 1.8 13-ps maf
PostPosted: Tue Oct 13, 2009 3:17 pm
PostPosted: Thu Oct 15, 2009 9:13 am
so all i have to do now is take my old 1.6 out and bolt the 1.6 engine mounts to the 1.8 with the pas pump ect
PostPosted: Mon Oct 19, 2009 8:25 pm
PostPosted: Mon Oct 19, 2009 10:26 pm
rs1800 injectors are green, think the 2.0 ones might overfuel slightly
