Fiesta-Si.com • View topic - My first proper project. need help?
It is currently Mon Mar 09, 2026 9:55 pm
PostPosted: Fri Sep 25, 2009 3:40 pm
Thinking of putting gsxr throttle bodies on a st170 inlet manifold onto my 1.6 si. Ive found a guide on the site but im just a bit confused. so i have just a couple of questions.
1. Will it be worth doing it to the 1.6?
2. Do i need to put an after market ecu on?
3. Will it have that much of a bhp gain?
Any help will be much appreiciated.
cheers olie. :)
PostPosted: Fri Sep 25, 2009 4:18 pm
I can't see why it wouldn't fit, but I can't see much gains either as the biggest problem witht eh 1.6 Si is the head is very restrictive.
I believe you can run them on a standard ECU but you will have problems so aftermarket is the way forward really.
The best modification to the 1.6 si is putting a 1.8 or 2.0 in as you get nice gains from the start, but it also then gives you you more scope for the future to add TB's as an example.
PostPosted: Fri Sep 25, 2009 6:54 pm
ITBs on an ST manifold? How's that work? Isn't the ST inlet a single body inlet?!
PostPosted: Fri Sep 25, 2009 7:40 pm
cheers that cleared the main problem i had. would it be worth doing. i might as well just get a 2.0 instead. :)
PostPosted: Sun Sep 27, 2009 9:31 am
Users browsing this forum: No registered users and 25 guests
