Fiesta-Si.com • View topic - can you fit a st170 enigne in a fez?
It is currently Sat Mar 07, 2026 11:10 pm
PostPosted: Sat Aug 29, 2009 9:59 pm
can you fit a st170 enigne in a fez? whats needed ...for the 1.6 si?
PostPosted: Mon Aug 31, 2009 10:06 am
ive seen it done to a red one in either fast or performance ford a while back....
alot of work if i remember, they used the 6 speed box too
PostPosted: Mon Aug 31, 2009 11:37 am
can do yes there a mk2 in mansfield with it and if i remeber dalsy on here has done it aswell
PostPosted: Tue Sep 01, 2009 11:56 am
its just the same as fitting a blacktop as thats all they are. Would be easy if you kept a 5 speed box and ran it with aftermarket management. You can fit the 6 speed. And run it on the proper ecu with focus clocks.. The red one is on fiesta turbo.com if you go have a look.
PostPosted: Fri Sep 04, 2009 12:08 am
I have a running blacktop 2.0 in my mk3.
Not as hard as you may think. Il be posting a guide soon.
PostPosted: Fri Sep 04, 2009 9:32 am
thanks
PostPosted: Fri Sep 04, 2009 11:19 am
