Fiesta-Si.com • View topic - OMEX 600 ecu??
It is currently Sat Mar 07, 2026 11:10 pm
 Post subject: OMEX 600 ecu??
PostPosted: Fri Aug 14, 2009 12:21 am
right im looking at building a 2l zetec with throttle bodies is te OMEX 600 ecu the best to use what the pros and cons of cheeper ones as well also will the OMEX 600 ecu be ok if i wanted to turbo as well?
 Post subject: Re: OMEX 600 ecu??
PostPosted: Fri Aug 14, 2009 12:23 am
what is this like as well ??http://cgi.ebay.co.uk/Omex-Throttle-body-kit-Ford-Zetec-1.6-1.8-2.0-16V_W0QQitemZ260454401264QQcmdZViewItem would u call this expensive?
PostPosted: Fri Aug 14, 2009 8:25 am
PostPosted: Fri Aug 14, 2009 10:38 am
yes that was what i wanted to do but with gsxr 1000 throttle bodies i want them now but i dont have the money for a ecu ...so u can? run throttle bodes on a standerd ecu then? this is going on a 1.6 first of all till i get my 2.0L
PostPosted: Fri Aug 14, 2009 12:14 pm
PostPosted: Fri Aug 14, 2009 12:34 pm
well the gsxr1000 should fit thow if i get the st170 intake at lest then wen i do get my 2L i dont rely need to but more than just the engine its self
PostPosted: Fri Aug 14, 2009 1:21 pm
PostPosted: Sun Aug 16, 2009 8:12 am
Megasquirt.
PostPosted: Sun Aug 16, 2009 10:42 am
can you not put the standerd fuel rail on first with the st170 intake after that?
PostPosted: Sun Aug 16, 2009 10:49 am
the inlets are different.
just get a series 3 zetec blacktop fuel rail.
PostPosted: Sat Aug 22, 2009 12:23 pm
some good info on here for fitting throttle bodies and megasquirt
PostPosted: Mon Oct 05, 2009 5:00 pm
will mega squert will work well with throttle bodies plus can mega squert work with turbo?
PostPosted: Mon Oct 05, 2009 5:23 pm
megasquirt can work with throttle bodies and can be later re-programmed to suit a later turbo installation with the addition of a MAP sensor, ive not gone down the megasquirt route as yet but considdering it, but it is a DIY setup and programme and not always a plug and play so you need to read up on it.
some good info here
PostPosted: Mon Oct 05, 2009 7:49 pm
that web site is the one i have been readin it seems good and also he can suplyy them pre built and with a basic set up for say a zetec engine
PostPosted: Tue Oct 13, 2009 7:01 am
Ive just been quoted near on a grand for OMEX 600 + Hand made wiring loom + Mapping.
Although worth it if youve built a half decent engine. As megasquirt mapping can ruin it if incorrect or done by people who bodge (of which I have heard one of the cheaper megasquirt people are bodges...)
PostPosted: Tue Oct 13, 2009 7:46 am
ill have to get you the website he give u the ecu plus a wiering loom plus any extras u want eg larnch controll for under 400 quid
PostPosted: Tue Oct 13, 2009 11:45 am
i would only trust extraefi
