Fiesta-Si.com • View topic - filling
It is currently Wed Mar 11, 2026 5:56 pm
 Post subject: filling
PostPosted: Wed Jul 01, 2009 10:17 pm
Right. well i remember when doing my rear reflector panel(my cars not a fez) I tried to smooth the lock hole and i alays got it perfectly flat looking yet when i applied the primer you could see it wasnt smooth and was a different level, if i filled a bit out from the lock and smoothed it in I would still get a splodge shape when i primed....i must of tried it about 7 or 8 times and could not get it to smooth in flawlessly...and as i am hoping to debadge my front bumper soon I'm thinking i may have the same proplem...so need some ideas as to why it was happening?
Cheers
 Post subject: Re: filling
PostPosted: Thu Jul 02, 2009 7:49 am
as soon as you apply paint it will always highlight changes in conours more so with when applying the gloss, how big an area are you trying to blend it into?
PostPosted: Thu Jul 02, 2009 11:35 pm
its just debadging so like this....but on the front bumper
[img]
http://www.club323f.com/ba/guides/refle ... ctor_1.jpg[/img]
basically removing the front badge:
Any idea how to make it flawless?
PostPosted: Fri Jul 03, 2009 10:57 pm
ha haaaa found the post right to get it to a good finish buz or rub down the area so all the paint is off it if its got a hole block it up from the back,
weld (if its metal) or plastic weld a plate behind (if its plastic) fill with fibreglass (plastic) or body filler (metal) if you can over lap the filler to the surrounding area it ul be better,
rub down with finner papers as you get closer to the plastic or metal as you get closer go over the original paint in very fine paper (feathering) around the filled hole,
on plastic finish off with body filler p38 i think its called to get it baby smooth,
spray it let it dry rub the paint down in fine paper or wet and dry paper is best (paint should high light any imperfections) if all is ok then let it dry and spray in primer and see how it comes out
:thumbsup:
edit;
just seen the first picture you may need to prime it with thick primer spray as you've used body filler it may come back to haunt you though if the reflector panel gets hot
PostPosted: Sun Jul 05, 2009 8:36 pm
PostPosted: Sun Jul 05, 2009 10:15 pm
PostPosted: Sun Jul 05, 2009 10:29 pm
sound mate only one thing, you didn't put a link to which one you prefer? :lol:
Cheers :D
PostPosted: Sun Jul 05, 2009 10:42 pm
PostPosted: Sun Jul 05, 2009 11:40 pm
so that'll do for the fibreglass filling stage yeye?
Sick....i just need to get a spare bumper then i'll have a go at it....wish me luck lol :)
PostPosted: Mon Jul 06, 2009 2:37 pm
Oh and just remembered...theres not so mugh a big hole behind but two litte ones where the locating pins for the badge go, they are about 2 mm each...would it be necessary to plastic weld these and iff so how?
Cheers
