Fiesta-Si.com • View topic - 1.1
 Post subject: 1.1
PostPosted: Sat Jun 27, 2009 9:22 pm
i have a g plate 1.1 and need more power.what engine is a straight swap??or any ideas on tweakin the 1.1
 Post subject: Re: 1.1
PostPosted: Sat Jun 27, 2009 9:48 pm
As crazy as it sounds, giving it a full service can give it a nice boost.
PostPosted: Sat Jun 27, 2009 9:49 pm
ok,sounds sensible.what about upgrading the carb??
PostPosted: Sat Jun 27, 2009 9:57 pm
In all honesty its not really spending much on a 1.1 engine, You could take the airbox off a 1.3 with an uprated panel filter will free up the revs.
As mentioned a full oil change and new plugs will help it, maybe a bit of redex in the carb too.
PostPosted: Mon Jun 29, 2009 7:26 pm
small shot of nos is the best thing I can think of other than changing the engine lol
PostPosted: Tue Jun 30, 2009 7:08 am
save money for a faster car? :thumbsup:
do as percy said, and with a service it should be a bit freer, but don't expect 100000bhp :)
PostPosted: Fri Jul 03, 2009 2:16 pm
you can bolt on WEBER IBF CARB i did that on my mk2 made it a bit quicker not sure what carb a mk3 has on as standard tho
PostPosted: Sat Jul 11, 2009 10:32 pm
PostPosted: Thu Jul 23, 2009 10:30 pm
1994 Ford Fiesta, 1.1 rattler. Tourmallard Green, RST alloys, with some twin piped rear silencer (<--- ha, the irony)
S reg Volvo C70 2.5 MPi low compression turbo
PostPosted: Wed Aug 19, 2009 2:15 pm
my first car was a 1.1 but i put a 1.3 engine in it was straight swap took a couple of hours and with a good service went really well, sort out the tappits with a k+n carb filter with a small oil breather would be spot on, only thing is if the engine has back presure oil will pour out of the oil breather and it will run dry causing what happened to mine
a masive bang and a fire on the side of the m6! lol :lol:
PostPosted: Wed Aug 19, 2009 4:55 pm
