Fiesta-Si.com • View topic - cold air feed
 Post subject: cold air feed
PostPosted: Fri Jun 19, 2009 8:03 pm
just looking for some advice and helpful info 2bh :)
firstly what size/diameter cold air duct do people use around the fog light? and also the diameter of the tubing/piping used?
other thing is, what route can i use for the piping. obviously i have to cut a hole in the slam panel.. not a big issue, but i was trying to imagine the route i would use... possibly relocate horn ?
Cheers, Grant
 Post subject: Re: cold air feed
PostPosted: Sat Jun 20, 2009 10:16 am
mine came as a kit from i think CBS, 60mm ducting £18, but the route is a pain to get around the washer bottle
mine fitted
previous thread
PostPosted: Sat Jun 20, 2009 11:42 am
you could also go down a scrappy and find a better suited washer bottle.
i think 1 guy used a susuki swift bottle.
then u will be able to keep the air feed pipe a lot straighter so it will aid the airflow.
