Fiesta-Si.com • View topic - 2.0 in a escort si?
 Post subject: 2.0 in a escort si?
PostPosted: Thu May 28, 2009 10:37 pm
is it possible for me to fit a 2.0 litre mondeo engine in to my escort si? and does any one know how easy or hard it is iv been told just to put sum injectors and cams out the mondeo engine in my 1.8 and a mondeo ecu and it will be just as good but not to keen on it? any opinions welcome facts aswel wuld be helpfull cheers :D :thumbsup:
 Post subject: Re: 2.0 in a escort si?
PostPosted: Fri May 29, 2009 1:11 am
same as fitting it into a fiesta except you gotta rewire the ecu, guides are on the net somwhere,
Msn - ryan@areyouserios.com
PostPosted: Mon Jun 01, 2009 10:01 pm
cant be too hard as said might be the same as the fiesta if you get the 2.0l engine as well as the manifolds and ecu you cant go far wrong and if the sump and alternator brackets are different change them to the orginal 1.8 sssssimple :thumbsup:
PostPosted: Tue Jun 02, 2009 8:12 pm
As said above.
If you were to put the 2.0ltr stuff in your 1.8, you would need a 1.8 130 spec ECU.
And then you'll be lucky to run 130bhp anyway.
