Fiesta-Si.com • View topic - black top convertion
 Post subject: black top convertion
PostPosted: Thu May 07, 2009 12:03 pm
hi my 2 litter silver top si is off the road with a terminal problem with the engine so will need to be fixed or replaced.
but 2 weeks ago my m8 had a stupid old bad rubber necking plow straight thruw his rear end.
so i was thinking of robbing the engine from it i know he will sell it to me cheap.
so i just wont to gather some info on doing this.
does any 1 have any info or know any 1 with a black top in on the site.
i know i will have to modify 1 of the mounts.
but would i have to use the wiring loom and ecu etc.
or could i run it on my dewy ecu and loom i have it now.
any 1 know :hmm:
 Post subject: Re: black top convertion
PostPosted: Thu May 07, 2009 12:49 pm
cookie 456 is doing this, not straight forwardi think search his threads :thumbsup:
PostPosted: Thu May 07, 2009 4:35 pm
I can't see why it won't run on the silvertop 2.0ltr ecu, as its basically the same engine!, maybe have to swap the sensors over tho.
Fitting wise, unsure, probably a few different mounts, but its been done easy enough.
PostPosted: Sat May 09, 2009 5:10 pm
Not quite straight forward as you would like im afraid!
Mounts/belt setup is different need to modify to suit. Im going to be using megasquirt i think, but i cant see why you cant use original loom and sensors, as paul says it practically the same engine.
PostPosted: Sun May 10, 2009 3:02 pm
PostPosted: Mon May 11, 2009 9:58 am
