Fiesta-Si.com • View topic - MAF BETTER WITH OUT WITHOUT?
PostPosted: Thu Feb 05, 2009 2:19 pm
i am wondering because of the ID of the maf (zetec 1.6)eingne weather its better with or with out in reguards to preformance
PostPosted: Thu Feb 05, 2009 2:27 pm
you need it mate, its there for a reason :lol:
PostPosted: Thu Feb 05, 2009 5:10 pm
but keep the maf. Induction kit or panel filter will help and a decent exhaust but the 1.6 is an untuneable engine as stated before :)
best off whacking a 2.0 in there :devil:
PostPosted: Thu Feb 05, 2009 6:23 pm
right i have cleaned this thread, i'm slowly getting sick of seeing snide and sarcastic replies to people asking for help and advice! if you dont have anything constrcutive or helpful to add to a topic DONT reply! simple no? :rolleyes:
if i see it again the person involved will be getting a warning or better yet a ban :thumbsup:
PostPosted: Thu Feb 05, 2009 7:20 pm
The engine uses 3 sensors to know what's going on, lambda, throttle position and the maf. If you unplug the maf it will usually run off the other 2 sensors and make a best guess at what air is coming in. With it you should be the most form your engine. If you are having problems with the maf fitted then it is probably faulty or needs a clean.
As mentioned its not economical to tune the 1.6 zetec, mainly due to the head/valves restricting things. You can add an exhaust and air filter but the gains won't be much, with that if you plan to drop a 2.0 later then you could still use them.
PostPosted: Thu Feb 05, 2009 9:44 pm
I had problems with my MAF before Ford Fair it wouldn't rev over 4500rpm. I disconnected it for the track time and it reved fine, however it was very thirsty in a 15 minute session I used nearly 1/4 of a tank (I usually get through 1/2 a tank for a whole track day)
I found when I dismantled it the thin wires inside were covered in muck, I cleaned them and performance was restored.
So in summary, I'd keep it plugged in for fuel economy and if working correctly it shouldn't restrict the engine performance.
Tied
PostPosted: Thu Feb 05, 2009 11:50 pm
ok will do thnaks guys
PostPosted: Tue Feb 10, 2009 8:46 am
no problem :)
how did the cleaning go?
PostPosted: Tue Feb 10, 2009 9:10 pm
thanks for askin it went sweet run rely well
PostPosted: Wed Feb 11, 2009 2:50 pm
Glad to hear it :)
PostPosted: Wed Feb 11, 2009 5:51 pm
nice one :thumbsup:
PostPosted: Mon Feb 16, 2009 11:10 am
when i unplug my maf its goes quite a bit better lol but runs rich and idles a bit rough.
PostPosted: Tue Feb 17, 2009 1:16 pm
PostPosted: Sat Mar 14, 2009 11:26 pm
