Fiesta-Si.com • View topic - cossie pistons fit zetec bottom end
It is currently Tue Mar 10, 2026 7:53 am
PostPosted: Thu Feb 05, 2009 11:58 am
will the cossie pistons fit the zetec bottom end as i might do a bottom end rebuild
PostPosted: Thu Feb 05, 2009 12:01 pm
top of my head says no mate
if you're talking cossie pistons out of a cossie engine :thumbsup:
If you are not increasing the bhp of the car, i think the pistons are ok, at a push maybe some ARP Conrod Bolts but the standard crank can handle 500bhp y0 :D
If you are turboing, calibra turbo pistons are good, but require overboring and a 2.1 turbo result etc etc yada yada and is expensive
PostPosted: Thu Feb 05, 2009 12:06 pm
going technical on me now :lol:
also is a 4-2-1 manifold better than a 4-1
PostPosted: Thu Feb 05, 2009 12:09 pm
and on that one, i have no idea
PostPosted: Thu Feb 05, 2009 12:23 pm
Course it is! All the exhaust gasses won't be meeting in 1 point at the same time with a 4-2-1, it's kind of filtered into the single pipe rather than being forced into it. If ya get me! :lol:
As for the pistons, no idea, all that knowledge has been long since lost in my ageing mind! :lol:
PostPosted: Thu Feb 05, 2009 12:24 pm
well the YB is really a 20 year old design engine at least, so i doubt it mate :rolleyes:
and not all the knowledge has gone yet Des :P
PostPosted: Thu Feb 05, 2009 12:26 pm
Naah, I can still remember where I park my car :lol:
PostPosted: Thu Feb 05, 2009 12:28 pm
fit remote start just in case, so if you forget you can hear it
*runs*
:whistle:
PostPosted: Thu Feb 05, 2009 12:36 pm
I've been meaning to get remote start fitted for a while now, but there's always something else to be spending money on :rolleyes:
But I'd never thought about it being a homing device aswell, nice one :D
PostPosted: Thu Feb 05, 2009 12:37 pm
cheers for that des i will be seeking one or get one custom made hopefully it will improve the mid range power
PostPosted: Thu Feb 05, 2009 12:38 pm
PostPosted: Thu Feb 05, 2009 1:06 pm
in short the answer to your question is no. the YB runs the same size pistons as a Pinto. hardly suprising as its the same block essentially unless its the thicker walled 200. anyways. the pistons in that are 90 mm (or thereabouts). the pistons in a 2.0 zetec are 85 with 86.5 being an acceptable size for an overbore. you can get performance pistons for a zetec. altho it would at this point be worth mentioning that the gudgeon pins are a bit of an arse to get out as they are interference fit in the rod and float on the piston. depending on the age of your engine there are 2 sizes of pin. 19mm and 13/16ths. (21mm in new money) and i have no idea of the pin size on a YB piston. but the essence of it is no they wont fit.
the 4-1 is better for top end horsepower youll lose a bit of lower end...the 4-2-1 will sacrifice a small amount of top end for some more useable grunt lower down
besides. cosworths are forced induction. why would you want a lower compression ratio in an N/A engine?
jam
PostPosted: Thu Feb 05, 2009 1:10 pm
just wondered and forgot about the comression ratio :(
