Fiesta-Si.com • View topic - mk5 Zetec s gear linkage
 Post subject: mk5 Zetec s gear linkage
PostPosted: Fri Jan 30, 2009 10:55 am
will these fit on an Si? because they have a shorter throw than the Si linkage
PostPosted: Wed Mar 04, 2009 2:30 pm
this is a zs gear linkage.
any1 know if this will fit? or has any1 got any pics of an si linkage which we can compare with?
PostPosted: Wed Mar 04, 2009 4:16 pm
Jack front end of car up and try swapping it.. gear linkages are eeeeeeeeasy to change ;)
PostPosted: Wed Mar 04, 2009 6:00 pm
yea m8 there easy to do get a haynes to help would you put up a post when you do this mod to let me know how it went and if it was any good plz m8 :thumbsup:
PostPosted: Wed Mar 04, 2009 6:11 pm
ill just try it! if it works i will be posting up 2 let people know how good it is! never seen any1 do this b4 so its a bit different i fink!
PostPosted: Wed Mar 04, 2009 11:37 pm
PostPosted: Wed Mar 04, 2009 11:51 pm
hi m8 do u want the tourque settings for the linkidge bolts as i have a haynes not sure weather ud need them or not just thaught it was worth mentioning :thumbsup:
PostPosted: Thu Mar 05, 2009 2:06 am
Make sure you measure the travel distance of the gear stick before and after, just because you may have heard or experianced it to be shorter in the mk5, it might not be the same for the mk3, and your mind WILL play tricks on you to make you think its shorter lol.
PostPosted: Thu Mar 05, 2009 11:51 am
PostPosted: Thu Mar 05, 2009 4:28 pm
Just to let you know, they do fit supposidly, and they are pretty much the same as the puma linkages, so should be good to see the results :D
PostPosted: Sat Apr 04, 2009 12:43 am
any update on this :hmm:
PostPosted: Sun Apr 05, 2009 1:32 pm
it wont fit as i tried this on my track car the mounting points of the linkage box are different to the si ones
PostPosted: Mon Apr 06, 2009 6:58 pm
i fell out with my mate so cudnt update soz!
thanks 4 the info thou big g!
