Fiesta-Si.com • View topic - Down To Thw Wires
 Post subject: Down To Thw Wires
PostPosted: Thu Jan 22, 2009 11:30 pm
need help when you put the 2.0 16v into the si 1.6 16v do you need to change the loom or does it just all plug in
Si 2.0 16v cheap and fast why not
 Post subject: Re: Down To Thw Wires
PostPosted: Thu Jan 22, 2009 11:51 pm
Should just plug straight in as far as i remember.I havent done the conversion *yet*.
PostPosted: Fri Jan 23, 2009 9:30 am
when you do the conversion, you use pretty much everything from your 1.6 engine and put it on the 2.0, no lom swaps required if you have a 1.6 16v already ;)
PostPosted: Fri Jan 23, 2009 3:47 pm
remember to change the ecu tho
PostPosted: Sat Jan 24, 2009 1:25 am
cheers lads just trying to get everything right so i don't balls anything up cos im re-buliding one from scratch the one i own has been on this web site be for it is know cos it run a 16 dead at santa pod but the car body work is f**ked to say the least so all parts off and on to a new si i will put sum pics up when i can (ps does anyone know how big the rear drums are)
thanx dave
PostPosted: Sat Jan 24, 2009 11:52 am
2 sizes of drum 180 and 203mm ring a bell the larger drums were optional. im not sure they made a difference in reality. the easiest way to tell the bigger drums are squarer looking the smaller ones are tapered from the centre bit of the hub if that makes sense.
hope that helps.
PostPosted: Sat Jan 24, 2009 12:27 pm
