Fiesta-Si.com • View topic - Have 2.0L throttle body fitted now, want some advice. . .
PostPosted: Mon Jan 19, 2009 11:17 pm
Hi, I fitted a 2.0L TB to my 1.6 Si yesterday, and have a couple of Q'z:
- Will it be ok with the 2.0L sensor (plug on the side) on or is it best to change it for the one off the 1.6? (im not even sure what this sensor does as the MAF is attached near the air filter of course).
- And have also heard that u need to drive it for 20 or so miles after and the ECU will slighty adjust to running on a different TB. . . fact or fiction?
Cheers
PostPosted: Mon Jan 19, 2009 11:48 pm
not sure on which sensor to use as mine ran with a 1.6 sensor and a 2.0 sensor, i'd fit the 1.6 one just in case, the sensor is your TPS( throttle position sensor :thumbsup: )
that might be fact, but to fully let it learn the fueling i think it needs to have the battery disconnected for a few hrs
PostPosted: Mon Jan 19, 2009 11:53 pm
PostPosted: Wed Jan 21, 2009 11:42 am
Use the 1.6 TPS and the 1.6 MAF, will run like a bag of balls on the 2.0l MAF! :thumbsup:
PostPosted: Wed Jan 21, 2009 12:06 pm
Doubt there is any point in fitting any larger parts on the 1.6 zetec.
So to save it running like a sack.. I wouldnt bother apart from different filter and exhaust.
PostPosted: Wed Jan 21, 2009 2:14 pm
Improves Throttle response slightly :)
PostPosted: Sun Jan 25, 2009 3:56 pm
PostPosted: Sun Jan 25, 2009 5:01 pm
Fair enough :)
Might slap the bigger 2.0ltr stuff on my RS1800 inlet :)
PostPosted: Sun Jan 25, 2009 8:16 pm
