Fiesta-Si.com • View topic - speaker wiring
 Post subject: speaker wiring
PostPosted: Sat Oct 04, 2008 2:11 pm
how do you wire 6x9 speakers into your headunit because im stumped on how to do it
 Post subject: Re: speaker wiring
PostPosted: Sat Oct 04, 2008 4:14 pm
French Crew
French Crew
just disconnect the wires to the rear speakers, cut the connector off and extend the wire to the 6x9's
Untouchable
PostPosted: Sun Oct 05, 2008 11:18 am
rear speakers were are they only have front ones behind the headunit the place were the rear speakers are is blank so dont think mine have them
PostPosted: Wed Oct 08, 2008 11:58 am
helppppp really need to wire my 6x9 up and quickly
PostPosted: Wed Oct 08, 2008 1:27 pm
if you have them they will be under the black plastic bit both sides of the parcel shelf.. tiny diddy things lol
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Wed Oct 08, 2008 9:39 pm
I very much doubt ford missed out rear speaker wiring on any of the fiesta looms, so the wiring will be under the rear plastics either side of the parcel shelf, whether you have standard speakers in there or not.
If for some reason there isnt any wiring then go to the plug on the back of the radio and make some wires from there to go to the back..
PostPosted: Sat Oct 11, 2008 10:51 am
my car doesnt have any speaker outputs on the plug so should i buy this so i could put some preouts in
http://www.caraudiodirect.co.uk/blaupun ... -5469.html
as i have a blaupunkt headunit and it will fit so give me some help please
PostPosted: Sat Oct 11, 2008 6:15 pm
Where does it have no speaker outputs?
PostPosted: Sat Oct 11, 2008 6:38 pm
on the block behind the headunit no wires are going into it so i assume there is so no rear speakers in my car
also when i start my car the music doesnt come on and the headunit will not register a cd and nothing comes out my door speakers
PostPosted: Sat Oct 11, 2008 6:41 pm
Does your sterio come to life at all?
Clearly there is a problem. Is your wiring set up correctly for your headunit?
Fitting extra wires into the block for speakers is simple if you know which pin on the sterio does what :) instruction manual will help.
PostPosted: Sat Oct 11, 2008 6:43 pm
it comes to life but nothing happens
i have this adaptor
http://www.fiestaturbo.com/forums/downl ... &mode=view
but on the end were you put the ford fiesta bit in there is no wire for rear speakers how do you attach the wire
PostPosted: Sat Oct 11, 2008 7:14 pm
So there is wiring for rear speakers from that adaptor... but not on the fiesta loom?
If that is correct... then on that adaptor the wires have writing on them.. like rear left etc..
Take a connection from them wires to the rear speakers, simple. :)
PostPosted: Sat Oct 11, 2008 7:24 pm
ok thanks atm i am more worried about my headunit so once that is fixed i will install my speakers
PostPosted: Sat Oct 11, 2008 7:31 pm
Well is the headunit able to work, buttons etc?
Make sure its wired in properly.. read the manual.
If there is no sound going to the fronts as well, are you sure they are wired in too? Sounds like someone got happy with the wiring at some point in its life
PostPosted: Sat Oct 11, 2008 7:45 pm
everything is wired as it should be, front speakers are wired correctly
the headunits buttons work and everything but no music
PostPosted: Sat Oct 11, 2008 7:51 pm
wiring fault between the headunit and the speaker wires then. make sure that adaptor is seated correctly
PostPosted: Sat Oct 11, 2008 7:55 pm
checked it and checked again mite look into a new headunit
PostPosted: Sat Oct 11, 2008 8:01 pm
PostPosted: Sat Oct 11, 2008 8:07 pm
good point didnt think of that will do it 2 my dads transit van
