Fiesta-Si.com • View topic - new brakes?
It is currently Tue Mar 10, 2026 7:53 am
 Post subject: new brakes?
PostPosted: Tue Sep 09, 2008 1:39 pm
im getting a 2.0 engine dropped into my 1.6 in a few weeks, and i was wondering what the best way to upgrade the brakes would be. i dont want to be splashing out huge amounts on an aftermarket kit. i was thinking a 285mm big brake kit from hi spec or something from another ford.
any suggestions would be much appreciated, thanks.
 Post subject: Re: new brakes?
PostPosted: Tue Sep 09, 2008 1:40 pm
cossie 4x4 set up or fiesta ST150 brakes will do :thumbsup:
PostPosted: Tue Sep 09, 2008 4:28 pm
theres some good info in the guides section links below. ive got the cosworth 278mm set up and in 4 trackdays have been great with no brake fade at all. only thing ive noticed is there is a missmatch between the standard Si mastercylinder size and the new calipers which results in more peddle movement and may be a bit less feel
PostPosted: Tue Sep 09, 2008 8:34 pm
i got mk3 mondeo brakes 300mm, cost me 90quid and they're awesome, easy to fit too.
Msn - ryan@areyouserios.com
PostPosted: Wed Sep 10, 2008 5:38 pm
i want to put braided hoses on them. can i use the fiesta ones or would i have to change the connectors etc.
PostPosted: Wed Sep 10, 2008 5:49 pm
got to demon tweeks and put in this item code
Product code:- GDRSFD0105-4P
Description:- 4 LINE KIT SUIT FORD FIESTA MK III 90-96 PLATED
should do the trick, i have them on my fez :thumbsup:
PostPosted: Wed Sep 10, 2008 8:52 pm
PostPosted: Wed Sep 10, 2008 9:03 pm
PostPosted: Wed Sep 10, 2008 10:02 pm
the only mod to fit the mk3 mondeo brakes are new hoses and to drill the hub out to 12m as opposed to 10mm which they are standard, less work to fit them that to fit the mondeo v6/cosworth fronts
also need 16"s to go over them.
