Fiesta-Si.com • View topic - oil breather filters
 Post subject: oil breather filters
PostPosted: Wed Aug 27, 2008 5:45 pm
i am looking to fit my pipercross breather filter but am unsure how to, do you attach it to the breather pipe or to the rockercover?? and what do you do with the hole in cam cover if u do?? could some give us a step-by-step please, cherrz
 Post subject: Re: oil breather filters
PostPosted: Wed Aug 27, 2008 11:13 pm
i attached mine to the rocker cover but fitted via a 15mm plumbing elbo so it was vertical so any oil drained back into the engine, but it doesnt breath to much
PostPosted: Thu Aug 28, 2008 4:46 pm
what happens when the original breather pipe gets blocked?
as i have a whistling noise coming from that area of engine. i think it's an air leak, but not sure. powers down too :doh:
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Fri Aug 29, 2008 12:34 pm
[quote="will121"]i attached mine to the rocker cover but fitted via a 15mm plumbing elbo so it was vertical so any oil drained back into the engine, but it doesnt breath to much
O WRIGHT, SO WHAT DID YU DO WITH THE PART THAT FITS ON THE AIR FILTER... block it? or is it alright to just leave it?
PostPosted: Wed Sep 17, 2008 10:24 pm
Not all aftermaket air filters have the bit to plug the pipe from the rocker cover to.
If it does, and your not planning on putting the pipe on there, just block it with a bolt or something, but something which wont get sucked through and into the engine :squint:
