Fiesta-Si.com • View topic - Throttle bodies under custom plenum, fez from FITP
PostPosted: Thu Jul 31, 2008 12:56 pm
At Fiesta in the park i found a mk2 fiesta running throttle bodies on standard management and a MAF sensor, it did this by using an almost plenum chamber over the top of the bodies instead of filters, into this was obviously ran intake pipe with a MAF on the end...was very ingenious to be honest. Does anyone know which car im on about and does anyone have any photos of this engine...i cant remember the colour of the car but it wasn't that far from the F-SI stand :)
I cant find the photos i took :( thank you as well :)
I think its an area not many people have looked into when doing TB's so gona look into it see if i can find pro's and con's
Looks clever tho...as long as it wont cost much to fabricate plenum and i have got the internal area correct for equal airflow to all bodies then it should work really well and possible save a good amount...plus its fairly unique & original ;)
O yea can you guess what im currently making for my fez then :D
PostPosted: Thu Jul 31, 2008 1:15 pm
i think i know the one your on about, was it near the FSI stand? where the traders where?
if so i think becks/me took a pic of it, i'll have a check for you ;)
PostPosted: Thu Jul 31, 2008 1:20 pm
that sounds very interesting would be great to see it too as im looking to convert to throttle bodies or motorbike carbs, with megasquirt or megajolt this winter.
PostPosted: Thu Jul 31, 2008 1:43 pm
sort of Like this?
Picture is from the bottom of the first page of this thread, its an S2.
PostPosted: Thu Jul 31, 2008 1:49 pm
PostPosted: Thu Jul 31, 2008 2:01 pm
PostPosted: Thu Jul 31, 2008 2:26 pm
cheers fella...not in there tho... :doh: just wish i could remember more details on it.lol
soon as i see the engine i will know tho...have it lodged in my head...need to find it.lol
PostPosted: Thu Jul 31, 2008 2:31 pm
:doh:
i'll check for you when i get home, i think it was orange in colour if its the one i'm thinking of :?
PostPosted: Thu Jul 31, 2008 2:37 pm
Im not sure if it was the orange one...i know the orange one had throttle bodies just not what im looking for :doh:
cheers for helping tho buddy :)
PostPosted: Thu Jul 31, 2008 3:59 pm
Don't see why its not possible, but it would need some tweaking as you wouldn't be able to use the OE TPS, ISVC and you would deffinatly need a remap. :)
I would have said still go standalone as theres more room for play, altering the map would be easier than having to pay wayne at chipwizards £600 to alter standard map! :)
PostPosted: Thu Jul 31, 2008 4:01 pm
What was the engine??
2.0 Zetec???
PostPosted: Thu Jul 31, 2008 6:37 pm
without sounding too negative, i really cant see the point in it. the whole idea of a set of throttle bodies/individual cabrs is to allow an equal amount of more air and fuel to each cylinder, if you were to enclose this then have it all the air running through the side via the MAF then you may aswell just have the one throttle body surely at the end how it is on a standard setup?
even if it does give you gains, the fabrication involved to make this custom plenum would probably cost you the same amount as a basic programble ecu such as megasquirt with more gains?
im not knocking it as i love to see something new and different but i will if it ends up costing just as much/is the same amount of work to build as conventional individual throttle body set up but gives you less in return if you see what i mean?
am interested in seeing pics of the car tho as its definatly an interesting concept!
http://WWW.S2RS.CO.UK
PostPosted: Tue Aug 05, 2008 6:30 pm
well wheres them pics at??? i wanna see!
PostPosted: Fri Aug 08, 2008 9:24 am
PostPosted: Fri Aug 08, 2008 9:42 am
i cant seem to find the one i thought i took a pic of :cry:
did find this tho
is this the one you ment?
PostPosted: Fri Aug 08, 2008 10:38 am
Nah terry thats just got a Powercross air box on that one! Expensive as well! :0
PostPosted: Fri Aug 08, 2008 10:57 am
nah i thought it wasn't, but was the only pic i could find in someone elses thread from FITP :cry:
PostPosted: Fri Aug 08, 2008 12:33 pm
