Fiesta-Si.com • View topic - Cossie Caliper Spacers
 Post subject: Cossie Caliper Spacers
PostPosted: Mon Jul 21, 2008 2:09 am
Just wondering if anyone is using anything other than 3 M10 washers to space the calipers out? Is there a better alternative?
PostPosted: Mon Jul 21, 2008 4:34 pm
Mine Cossie kit came with spacers which were 10mm (approx) thick, so I guess you just need to
find out the exact size they need to be spaced out and get some made up.
Hope this helps
Emlyn
PostPosted: Mon Jul 21, 2008 6:18 pm
i went down my local industrial estate and got some stainless steel rod then used my missus' stepdads lath, drilled it out and cut it to the corrrect length. the rod cost me £5 and they would of done it for me for £20 they said but i figured no point if i can do it myself so just nip down your local industrial estate there will be a few steel merchants/fabricating places that you never knew exsisted! handy if you need the odd bit welding done on bits too
http://WWW.S2RS.CO.UK
