Fiesta-Si.com • View topic - Few questions before i start [2.0lsi project]
PostPosted: Sun Jul 06, 2008 10:10 am
In the following months im going to start building a 2.0l si, and i have got few questions before i start and would also like some genrall advice, and people's views on my plans etc.
At the end of the month im going to be buying a 2.0l zetec engine/and the correct ecu (deep,desk,dewy) and going to strip it complety down and rebuild it. I take it i am best changing the head gaskets, and all the other gaskets, ike manifolds etc? Also going to do the cambelt. What do you lot recomend in the way of a good cam belt kit and gaskets?
What would be a good exhaust manifold to use?
Whats the best inlet to use?
best gearbox?
also going to get 16inch mondeos
ajustable lower arms
coilovers
PostPosted: Sun Jul 06, 2008 10:23 am
PostPosted: Sun Jul 06, 2008 11:32 am
When rebuilding engine, change everything otherwise its not worth doing. so:
sump gasket
front crank seal
rear crank seal
oil pump/front seal carrier gasket
rear crank seal carrier gasket
pick up pipe gasket
head gasket
manifold gaskets
valve stem seals
cam cover gasket
cam seals
cam belt, tensioner and the two guide pulleys
waterpump and gasket
And finally make sure you use a good quality oil and filter. if keeping 2.0 oil pump you will need a cvh oil filter other wise it will hit the chassis leg.
To expand on what onslack said about the gearboxes, as you go further down you lose acceration but gain top end
1.1 box
1.6 si box
1.8 xr2i box
1.6 xr2i box
rs1800/rst box
diesel gearbox
or escort rst series2 box will bolt straight on, has same ratios, about, as rs boxes but with added bonus of LSD :)
Adjustable lower arms.... i made mine myself, got some ok ish lemforder ones from my work, drilled out the rivets for balljoints, dilled the holes out so they where slightly longer and used a bolt and double nutted it. works a treat, no stupid amounts camber.
Might not have rosejoints in them but can allways get some polybushes pressed in. And its easier ot change ball joint when it goes.
Edit, where abouts are you from?
PostPosted: Sun Jul 06, 2008 3:38 pm
thanks for the adivce guys, going to be looking a burton power then, because il want to rebuid the whole engine, will you notice the diffrence with a whole rebuilt engine compared to an old used one?
PostPosted: Sun Jul 06, 2008 9:47 pm
PostPosted: Mon Jul 07, 2008 9:57 pm
Will do paul, just need to get some batteries for camera.
