Fiesta-Si.com • View topic - Lowering my si
 Post subject: Lowering my si
PostPosted: Mon May 12, 2008 6:18 pm
was just wondering if the lowering springs and shocks i had on my old mk3 fiesta 1.1 will fit of my mk3 1.6 si
any help would be appreciated
 Post subject: Re: Lowering my si
PostPosted: Mon May 12, 2008 6:21 pm
depends on the year of the vechicles primarily, if its a 94-96 reg they should fit, but there are some known variances to this
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Mon May 12, 2008 6:31 pm
my old one was an L reg and my new one is an N reg
PostPosted: Mon May 12, 2008 6:44 pm
i should think they would, but not 100%
RR - TBC
PostPosted: Mon May 12, 2008 6:51 pm
kk cheers fella il jus av to take the carpets out and av a look at the fittings
PostPosted: Mon May 12, 2008 7:34 pm
The springs will. Just not the shocks 8-)
PostPosted: Tue May 13, 2008 11:00 am
The Nude Numpty
The Nude Numpty
If your old fiesta was a mk3.5 then they should. If it is a 3.5 it will have a flappy petrol cap. If it is just a mk 3 then they can fit but will require a shim fitting.
PostPosted: Wed May 14, 2008 10:16 pm
onli way 2 find out mate is to try them, nd wer in south wales r u from? get sum pics of ur car up on here!! :D
PostPosted: Thu May 15, 2008 12:18 am
mk3 ones will fit into mk3.5 hubs if you are willing to mod the knuckle so it tightens up more around the slightly thinner mk3 shocks.
or its easy enough to swap everything over to mk3 hubs
or cheaper to get put your springs on the mk3.5 shocks instead.
