Fiesta-Si.com • View topic - engine modifications
 Post subject: engine modifications
PostPosted: Thu May 01, 2008 1:26 pm
hi there fellow blue oval boys
just looking for some guidance
i am looking to make my 1.6 fiesta quicker, i think i am going to go for a few bits from a 2.0 zetec engine so it would be the throttle body injectors and cams, i have been told this will make a big difference to the car, has anyone done this or just your thoughts on this
 Post subject: Re: engine modifications
PostPosted: Thu May 01, 2008 1:33 pm
i'm not sure the 2.0 stuff fits the 1.6 i know the 1.8 and 2.0 zetecs are interchangable but not the 1.6
you're better off putting a 2.0 in :devil:
PostPosted: Thu May 01, 2008 2:08 pm
You could Fit the TB off the 2.0l and thats about it, Injectors would be pointless, cams would cause valve bounce. :)
Just slap the 2.0l in! :)
PostPosted: Thu May 01, 2008 5:40 pm
that was what i was thinking of doing it would be easy due to my uncle being a mechanic am i right in thinking the 2.0 is 136bhp
PostPosted: Thu May 01, 2008 5:57 pm
PostPosted: Thu May 01, 2008 6:13 pm
iirc matt's 2.0 got 131bhp and 149ftlb's :D still pretty damn quick, wont set the world on fire but will keep you happy for a while
but as said above drop a 2.0 in ;) you'll find all the info you need here :D
PostPosted: Thu May 01, 2008 6:59 pm
PostPosted: Fri May 02, 2008 12:20 am
how about cams from a 105ps 1.8? just wondering as i could get some cheap is all :)
PostPosted: Sun May 04, 2008 6:56 pm
PostPosted: Sun May 04, 2008 11:02 pm
except you have a race manifold and decat :red: :red:
i say conservative rollers :hsugh:
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Mon May 05, 2008 11:41 am
PostPosted: Mon May 05, 2008 2:42 pm
The Nude Numpty
The Nude Numpty
PostPosted: Sat May 10, 2008 4:08 pm
PostPosted: Sat May 10, 2008 4:54 pm
what do these measurements mean though, or am i being dense? :nerd:
what determines what would work/what wouldn't
RR - TBC
PostPosted: Sat May 10, 2008 10:44 pm
im afraid i cant really answer that :(
was hoping somebody would be able to enlighten me :lol: woodsy??
PostPosted: Tue May 20, 2008 10:38 pm
Onslack's other half
all calling woodsy!
PostPosted: Sun May 25, 2008 5:36 pm
Bolting any parts on from a larger spec engine will do nothing for performance and will most likely decrease the overall performance.
Zetec Mapping Services
PostPosted: Tue May 27, 2008 1:42 pm
What would you guys do without me :lol: :lol:
Those are the size of the valves, are they not???
No good for determaining cams im afraid :(
Its the profile that tells you about your lift and duration etc.
As for fitting cams on from big brother, its rather model/manufacturer dependant, same as with heads, as to the ease of compatability.
For example, Hondas engines are all part of a "series" grouping, (like nearly all companies......your CVHs, your Zetecs etc.)The reason they are grouped is because they have similar features. In the case of Honda, all engines in a series have the same bore, meaning a higher spec head can be fitted, to reduce comp. ratio and increase power.
The vauxhall 54deg. V6 engines can have the cams changed. The Vectra GSi has an extra 25bhp compared to its lower spec counterparts because MSD fitted inlet cams from the 3.0, as they fit straight into the 2.5 ;)
The trouble with Zetec family of engines, is that they all have the same stroke, meaning the bores all change with capasity. This rules out interchangablity (for the most part....any thing is possible) Fitting a 2.0 head for example would play havoc with your comp. ratio.
I do however understand cookie has fitted one to his though, and id be very interested to hear how he got around any problems :nerd:
See.......I do have my uses :lol:
PostPosted: Wed May 28, 2008 12:43 am
TBH either do the 1.6 up to see how much power you can get from it with proper cams..
or more bang for buck, swap it for a 1.8 130spec, 2.0ltr or rst engine
PostPosted: Wed May 28, 2008 2:13 am
Piper do a Fast road cam for the 1.6 which they claim gives extra horses. £200 on an exchange basis
They don't list a mild cam for this engine.
Im getting piper cams for 3 of my cars, and have already orgainised to do a batch buy with a couple of others.
May orgainise some sort of bulk order later in the year if anyone else would be interested.
Better numbers makes my haggleing hat heavier whilst on the phone ;)
I'll put up a thread when i'm ready to do so, but let me know if any of you are interested (not just the fiesta and not just the 1.6, if piper list them, i'll give it a go) ;)
