Fiesta-Si.com • View topic - fitting 1.6 cvh efi manifold to 1.4 cvh efi
PostPosted: Thu Apr 17, 2008 11:31 pm
does the 1.6 exhaurst manifold make a difference on the 1.4?
PostPosted: Fri Apr 18, 2008 11:07 am
if they are different manifolds they 1.6 probably won't fit, and if it does it won't make any noticeable difference....
if you wanted extra power you could drop a 1.6 xr2i or Rs turbo engine in there without too much difficulty..
if you can't afford that an wanted extra noise/minimal gains in power i'd hollow you cat converter, and drill the airbox while you at it.
HTH
andy
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Sun Apr 20, 2008 10:54 am
I can tell you the inlet manifold does, russ_si did it on his, apparently it made a fair bit of difference.
PostPosted: Thu May 01, 2008 5:50 pm
wa bout a 1.6 head?? not sure if it will fit thou :? xr2i inlet sounds like a plan 8-)
