Fiesta-Si.com • View topic - Brake question
 Post subject: Brake question
PostPosted: Fri Apr 11, 2008 11:17 am
i've got my M.O.T coming up soon and i know my brake discs are shot and need to replace them pre-MOT.
Like most of you though, when something needed replacing i prefer to upgrade if possible-
there are a couple of strict conditions though-
They must be cheap
I don't have much money to spend as i've just bought a suit for interviews which cost me a fortune :shock:
Easy to Fit
i haven't got hardly any time free before the M.O.T so it must be a quick/hassle free modification...
I've been wondering about the RS2000 brake discs, but at the moment i am only after the discs (and pads). Would this work using my standard calipers?
also, i have looked for calipers, but non are available at a good price for me at the moment and obviously i haven't got much time to wait for them....
so yeah, any suggestions on a bolt-on brake disc upgrade?
cheers
any info apreciated
andy
L333SYA - Ford Cougar 2.5 V6
RR - TBC
 Post subject: Re: Brake question
PostPosted: Fri Apr 11, 2008 11:21 am
Discs are no where near as important as pads dude, keep what you have as standard as it's fine.
How much are mintex for yours?
Edit: just read it all and you do want to upgrade.
hang on i'll find a good link for you to read before buying anything.
PostPosted: Fri Apr 11, 2008 11:27 am
this is all gti-6 related but it should help with yours in parts.
HTH!
PostPosted: Fri Apr 11, 2008 12:19 pm
The Nude Numpty
The Nude Numpty
If you want some RS2000 discs I have some, part worn mind. They are grooved and I dont want much for them. Just thought if you need summit quick to get thro MOT. See them here.
viewtopic.php?f=10&t=10835
Give me a PM if you want and can arrange price etc.
PostPosted: Fri Apr 11, 2008 1:20 pm
Wow that is alot of info on bedding brakes in etc., think removing the caliper on the fiesta is slightly easier though.
i dont think i'd need to remove any brake lines/hoses to swap the discs would i?
cheers
RR - TBC
PostPosted: Sat Apr 12, 2008 11:46 pm
French Crew
French Crew
no, just tie the calipers up when you take them off to avoid putting strain on the hoses
Untouchable
PostPosted: Sun Apr 13, 2008 12:26 am
should be nice and easy job to do then
cheers
:D andy
RR - TBC
