Fiesta-Si.com • View topic - Fitting 2ltr mondeo hubs to mk3 fiesta
PostPosted: Tue Apr 08, 2008 1:14 am
anyone know if you can just un-bolt the brake set up on the 2ltr mondeo and bolt it to a mk3 fiesta?
PostPosted: Tue Apr 08, 2008 12:51 pm
mole259 is the man to ask about this, if i remember rightly he did this to his fiesta
PostPosted: Wed Apr 09, 2008 12:03 am
The answer is no
To bolt them on you need to drill the caliper holes in the Si hubs
Si hubs have 10mm bolt holes and the mondeo brakes caliper bolts are 12mm
So you need drill out the hub holes out to 12mm and cut about 1/4 of the end of th bolts as theyre slightly too long
you also need to grind abit off the face of the hub when you put them on so they have a good fit (the calipers that is)
So
Drill the caliper bolt holes to 12mm
Grind the face of the hub down by about 3-4mm (best results professional lathe work)
cut about a 1/4 off the mondeo caliper bolts
Once youve done that the should fit and work a treat as do mine, though we ceated by not using a lathe but i havent had any problems with them done with a grinder
PostPosted: Wed Apr 09, 2008 9:15 pm
Or instead of grinding 3-4mm of anything, space the disks out 3mm. thats what we did on mine and my mates car, no problems. :)
PostPosted: Wed Apr 09, 2008 9:27 pm
what do you mean?
put a spacer disk in between the wheel and hub?
PostPosted: Wed Apr 09, 2008 9:44 pm
you need to put a spacer before the brake disk, or do some machining off like mole said.
this therefore spaces your front wheels out 3mm.
PostPosted: Thu Apr 10, 2008 6:22 pm
wouldn't i need to extend threads for the wheel nuts?
PostPosted: Thu Apr 10, 2008 10:02 pm
