Fiesta-Si.com • View topic - escort rs gearbox on fiesta si HELP
PostPosted: Sat Mar 15, 2008 4:03 pm
hiya iv got a mondeo 2.ol zetec engine in my fiesta si and iv put a escort rs turbo 90 spec lsd gear box in it and when drinving the speedo work fine but when driving and take the fooy off the pedal the speddo drops down to 0 mph or some times only drops to 20mph iv replaced the speedo cable and the same?? be i put rs gear box in it work fine on my si gear box?? and pretty sure not the clocks could there be anything wrong with gear box?? please help thanks kyle?????
2.0l 16v zetec kent cams-vernior pully ashley 4-2-1-manifold stage 2 head fse boost valve full powerflow exhaust running 161bhp at the wheels!!!! SHITY type r's u gona get ripped!!!!! 0-60=6.6sec woophoo 145mph on m6 motorway woopwoo
PostPosted: Sat Mar 15, 2008 7:20 pm
PostPosted: Sat Mar 15, 2008 8:26 pm
PostPosted: Sun Mar 16, 2008 9:40 pm
hate to be the bearer of bad news...take the speedo drive out of the box..its held in with a roll pin....make sure thats all alright..failing that your diff bearings are well worn and in need of replacement
if you have replaced the cable and the clocks....or tried another set...then this is the most likely culprit
Jam
