Fiesta-Si.com • View topic - Painting rear ARB
 Post subject: Painting rear ARB
PostPosted: Thu Mar 06, 2008 12:27 pm
The Nude Numpty
The Nude Numpty
I know there isnt much point in painting it any other than black, but Im doing the twin ARB trick late this month or next month. Wanted to paint the ARB's yellow. Would I be best to just do this in yellow hamerite if I can find some, or do it with rattle cans? Also, I know you need to use longer bolts. Im a bit para about getting some longer bolts which are not strong enough and having them snapping. Anybody got any part numbers or advice on which ones to use?
Cheers, Fletch.
PostPosted: Thu Mar 06, 2008 11:01 pm
PostPosted: Thu Mar 06, 2008 11:05 pm
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Fri Mar 07, 2008 9:55 am
The Nude Numpty
The Nude Numpty
PostPosted: Fri Mar 07, 2008 11:12 am
PostPosted: Fri Mar 07, 2008 12:12 pm
PostPosted: Fri Mar 07, 2008 12:29 pm
PostPosted: Fri Mar 07, 2008 12:35 pm
PostPosted: Fri Mar 07, 2008 12:41 pm
this is an easier methiod than doing the ZS beam conversion as far as i know, the ZS beam sticks the track out 10mm i think and you need to mod the handbrake cable
so this is a case of undoing your old ARB then offering the other one up with its brackets and bolt both back in place
to me this is easier and less of a ball ache :lol: :homo:
there was a guide in fast ford a few months back on it ;)
*i'm going by what i have read on the ZS beam mod,so i could be wrong*
PostPosted: Fri Mar 07, 2008 12:49 pm
PostPosted: Fri Mar 07, 2008 12:54 pm
PostPosted: Fri Mar 07, 2008 12:59 pm
PostPosted: Fri Mar 07, 2008 7:59 pm
The Nude Numpty
The Nude Numpty
It is meant to stiffen up the back making the front grip better? I think lol. The reason Im doing is when I got my tracking done aggggess ago, I found my rear beam was bent, leading one of the wheels camber to be out 3 degrees lol. So I get a new rear beam from the scrappers for £45 and it had the ARB on it, now as Ive got two may as well do it.
PostPosted: Sat Mar 08, 2008 12:22 am
