Fiesta-Si.com • View topic - rs1800 more power?
It is currently Tue Mar 10, 2026 7:43 am
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
 Post subject: rs1800 more power?
PostPosted: Sun Feb 17, 2008 6:01 pm
PostPosted: Sun Feb 17, 2008 8:56 pm
PostPosted: Sun Feb 17, 2008 10:02 pm
PostPosted: Sun Feb 17, 2008 10:33 pm
yer im guna take both fogs out soon and replace with cold air feeds. ive got a pipercross on at the mo and a powerflow exhaust! is there any beta inlets that will work with it?
PostPosted: Mon Feb 18, 2008 1:05 am
ITBs 8-) not cheap or from ford though
As far as i know best Fiesta inlet is an RS1800 one. Think you can also fit a plastic 2.0 jobbie, but not sure of any benefits over RS, apart from wider availabilty.
PostPosted: Mon Feb 18, 2008 1:11 am
whats ITB's?
PostPosted: Mon Feb 18, 2008 1:25 am
Individual Throttle bodies, whereas a 1.6 Si, has one puny throttle body shared amongst all 4 inlet ports, the conversion would have one throttle per port. Freeing up lots of air flow, and not being restricted by the manifold.
Expensive and requires a change in management though.
PostPosted: Mon Feb 18, 2008 9:03 pm
fook that then :lol:
PostPosted: Mon Feb 18, 2008 9:37 pm
PostPosted: Mon Feb 18, 2008 9:50 pm
PostPosted: Mon Feb 18, 2008 10:03 pm
PostPosted: Thu Feb 21, 2008 5:32 pm
yer jp tuning said that you need suzuki gsx 750 thottle boddies! are megasquirts better than superchips?
PostPosted: Thu Feb 21, 2008 6:07 pm
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Thu Feb 21, 2008 8:13 pm
Exactly.
Megasquirt (and similar), allows for a custom mapping set-up, and is therfore essential for enableing the use of anything other than the standard ECU for fueling. This can be from anything as simple as adding/removing something as trivial as a lambda sensor or AFM sensor set-up, to programming a turbo/supercharger or TB.
a "superchip" (or similar) piggy-back on the existing ECU to give additional maps. This is simply adding or reducing fuel at certain points in the rev-range to optimize the existing set-up.
The main trick a chip has up its sleeve, is significant richening of the air/fuel ratio at WOT (Wide Open Throttle)!!
PostPosted: Fri Feb 22, 2008 6:50 pm
PostPosted: Sat Feb 23, 2008 12:55 am
PostPosted: Fri Mar 14, 2008 8:09 pm
if i got a mondeo 2 litre throttle boddie would it be better in preformance terms than my rs1800 1?
PostPosted: Fri Mar 14, 2008 8:14 pm
nah i think the 2.0 one and the rs1800 one are the same
stick with the rs one ;) no modding required 8-)
PostPosted: Fri Mar 14, 2008 8:17 pm
sweet
PostPosted: Fri Mar 14, 2008 11:24 pm
Users browsing this forum: No registered users and 26 guests
