Fiesta-Si.com • View topic - 1.8 16v conversion into 1.4 si - Help me please guys!
It is currently Sat Mar 07, 2026 6:04 am
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Mar 13, 2010 12:46 am
haha yeah not far mate.
PostPosted: Sat Mar 13, 2010 1:37 am
well you know where i am if you need :)
PostPosted: Sat Mar 13, 2010 3:49 pm
thank you mate.
PostPosted: Tue Mar 30, 2010 11:40 pm
wouldn't a 2.0l conversion be easier? i may be totally wrong of course...
PostPosted: Wed Mar 31, 2010 12:50 am
technicly now, you got things like the sump oil pick up etc etc
PostPosted: Wed Mar 31, 2010 8:40 pm
cheers jony :) so when i get round to converting my 1.4si, i should go for a 1.8 instead of the 2.0l?
PostPosted: Wed Mar 31, 2010 8:46 pm
its all about the turbo guys!!
PostPosted: Wed Mar 31, 2010 9:08 pm
how much harder is it then though ? :(
PostPosted: Wed Mar 31, 2010 9:42 pm
not a lot to be fair dude,if anything will be easier. only reason mines taking so long is due to the lack of funding, lol
PostPosted: Wed Mar 31, 2010 11:51 pm
how much more :O ive never really understood or looked into a turbo before to be fair.
PostPosted: Thu Apr 01, 2010 5:10 am
ive heard a good few say that turbo'ing the 1800 is better than the 2.0 as the bottom end on the 1.8 is stronger
:homo: :chill:
PostPosted: Thu Apr 01, 2010 5:19 am
as for turbo'ing funds, you can go the cheaper 'budget' route whichc an be done for less than a Grand, it involves using two Focus RS head gaskets and a de compression plate to lower the compression ratio a bit, using escort RS turbo exhaust manifold and turbo, and modifing either the RST inlet to fit the zetec, a modified zetec cast inlet, or using a modified rover turbo inlet, the injectors need seing too also some use vauxhall redtop ones, but personally i see that as a sin :insanity: also using an RST oil feed for the turbo that connects to the oil pressure sensor, but your restricted to less than a safe 10psi of boost due tot he gasket and compression plates
although the Frst T2 can be used but ive seen it being more difficult to find the right hybrid hoses for it
or using the proper stronger and more reliable route but working ont he internals, forged low compression pistons, stronger steel Con rods a better headgasket turbo oil feed from the sump a custom made manifold and turbo flange
its alot more rewarding and wont require you to come back in the near future to make it a proper turbo build, also you can run as much boost as your turbo can support
:halo:
PostPosted: Thu Apr 01, 2010 5:24 am
lol forgot to mention management, some use the frst manangement but thats more for the budget build, Omex or megasquirt is used on the proper route amounst others, but more expensive, but our then given the choise to adjust your boost and mapping
PostPosted: Thu Apr 01, 2010 9:14 am
1.6 cvh turbo drops straight in no messing about with mounts, run with ofab, T3 etc... job done, lol
PostPosted: Thu Apr 01, 2010 10:42 pm
that turbo talk lost me! so its cheaper to simply convert to a higher powered engine than doing a turbo?
